multiple map instances with linked zoom/extents?
2958
10-10-2013 07:34 AM
TravisLogan
Is there a way to 'link' the extents / zooms of multiple map instances?
This seems pretty easy in google maps api (e.g. using map.bindto()) but can't seem to find an equivalent in the ArcGIS api...
I'm quite new to javascript so any help on this would be great:
Here's is my code so far that sets up my two maps. I will eventually be adding different KML layers etc for comparison between thetwo but for now am just trying to link the extents
thanks
Travis
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>TEST</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">
  <style>
   html, body {
    height: 100%;
    width: 100%;
    margin: 0;
    padding: 10;
   .esriBasemapGallerySelectedNode .esriBasemapGalleryThumbnail {
    border-color: #66FFFF !important;
   #map {
    padding: 10;
  </style>
  <script>
   var dojoConfig = {
    parseOnLoad : true
  </script>
  <script src="http://js.arcgis.com/3.7/"></script>
  <script>
   dojo.require("dijit.layout.BorderContainer");
   dojo.require("dijit.layout.ContentPane");
   dojo.require("esri.map");
   dojo.require("dijit.TitlePane");
   dojo.require("esri.dijit.BasemapGallery");
   dojo.require("esri.arcgis.utils");
   var map;
   function init() {
    map = new esri.Map("map", {
     center : [-73.049, 48],
     zoom : 5,
     basemap : "streets"
    map1 = new esri.Map("map1", {
     zoom : 5,
     basemap : "streets"
    var basemapGallery = new esri.dijit.BasemapGallery({
     showArcGISBasemaps : true,
     map : map
    }, "basemapGallery");
    var selectionHandler = dojo.connect(basemapGallery, "onSelectionChange", function() {
     dojo.disconnect(selectionHandler);
     //add kml layer to the map
    basemapGallery.startup();
    dojo.connect(basemapGallery, "onError", function(msg) {
     console.log(msg)
   dojo.ready(init);
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit.layout.BorderContainer"
  data-dojo-props="design:'headline', gutters:false"
  style="width:100%;height:100%;margin:0;">
   <div id="Main"
   data-dojo-type="dijit.layout.ContentPane"
   data-dojo-props="region:'center'"
   style="border:1px solid #000">
    <div id="map"
     <div style="position:absolute; right:20px; top:10px; z-Index:999;">
      <div data-dojo-type="dijit.TitlePane"
      data-dojo-props="title:'Switch Basemap', closable:false, open:false">
       <div data-dojo-type="dijit.layout.ContentPane" style="width:280px; height:280px; overflow:auto;">
        <div id="basemapGallery"></div>
       </div>
      </div>
     </div>
    </div>
   </div>
   <div id="sidebar"
   data-dojo-props="region:'left'"
   style="border:1px solid #000;width:25%;">
    <div id="map1"
    style="height:65%"></div>
    <div id="Info"
    data-dojo-props="region:'bottom'"
    style="border:1px solid #000;height:32%"></div>
   </div>
  </div>
</body>
</html>
ManishkumarPatel
Hi Travis,
Do you want to set the extent from one map to another. If yes please find the attached code:
<!DOCTYPE html>
<html>
<head>
    <title>TEST</title>
    <style>
        html, body
            height: 100%;
            width: 100%;
            margin: 0;
            padding: 10px;
        #map
            padding: 10px;
    </style>
    <script>
        var dojoConfig = {
            parseOnLoad: true
    </script>
    <script>
        var map,map1;
        function init() {
                center: [-73.049, 48],
                zoom: 5,
                basemap: "streets"
                zoom: 5,
                basemap: "streets"
                showArcGISBasemaps: true,
                map: map
            var selectionHandler = dojo.connect(basemapGallery, "onSelectionChange", function () {
            dojo.connect(basemapGallery, "onError", function (msg) {
                console.log(msg)
            dojo.connect(map, "onExtentChange", setMap1Ext);
        function setMap1Ext(ext) {
            map1.setExtent(ext);
        dojo.ready(init);
    </script>
</head>
        style="width: 100%; height: 100%; margin: 0;">
        <div id="Main"
            style="border: 1px solid #000">
            <div id="map"
                data-dojo-props="region:'center'">
                <div style="position: absolute; right: 20px; top: 10px; z-Index: 999;">
                        <div data-dojo-type="dijit.layout.ContentPane" style="width: 280px; height: 280px; overflow: auto;">
                        </div>
                    </div>
                </div>
            </div>
        </div>
        <div id="sidebar"
            style="border: 1px solid #000; width: 25%;">
            <div id="map1"
                style="height: 65%">
            </div>
            <div id="Info"
                style="border: 1px solid #000; height: 32%">
            </div>
        </div>
    </div>
</body>
</html>
Hope this helps.
Regards,
Manish
