Mouse wheel zoom too quick with map view and scene view
2105
02-06-2025 02:34 PM
TedZhou
Our customers complain the mouse wheel to zoom in and zoom out a little too quick for both map view and scene view.
Not sure how to refine the mouse wheel configurations with ArcGIS JavaScript SDK
"dependencies": {
"@arcgis/core": "^4.29.2",
"@esri/calcite-components-react": "^2.6.0",
Looking forward to your tips and solutions...
Kind regards,
Ted
TedZhou
I saw those settings for old ArcGis as below:
esri.config.defaults.map.zoomDuration = 250; //time in milliseconds; default is 250
esri.config.defaults.map.zoomRate = 25; //refresh rate of zoom animation; default is 25
esri/config | API Reference | ArcGIS API for JavaScript 3.46 | ArcGIS Developer
But I did not see relevant information within config class of latest ArcGIS Maps SDK for JavaScript (4.31)  yet
config | API Reference | ArcGIS Maps SDK for JavaScript 4.31 | Esri Developer
TedZhou
require([
  "esri/Map",
  "esri/views/MapView"
], function(Map, MapView) {
  // Create a map
  var map = new Map({
    basemap: "streets"
  // Create a view and set the zoom rate and duration
  var view = new MapView({
    container: "viewDiv",  // Reference to the DOM node that will contain the view
    map: map,              // Reference to the map object created before the view
    center: [151.2093, -33.8688], // Longitude, latitude
    zoom: 10,              // Initial zoom level
    zoomRate: 0.5,         // Zoom rate (default is 0.1)
    zoomDuration: 1000     // Zoom duration in milliseconds (default is 500)
BillFox
MVP Notable Contributor
JonathanDawe3
I would also check whether you have LODs defined in you map.
If you have not due to one of the reasons explained there, then the mapview effective LODs defaults to null. In my experience this causes extremely sharp zooming when using the mouse wheel.
TedZhou
Thanks for your kind tips and brilliant suggestions.
I will examine anything we could be refined with LOD.
Best wishes to Jonathan.
