mobile support not working on js api 4.x
2750
01-17-2023 04:05 AM
litch
hey, I'm using the esri github "js-api-resources" to kickstart creating a new app.
the photo is an unchanged build but the mobile support is missing(?).
the web-samples and live builds seem to work (same css). anything im missing or should change? this is the webpack sample "straight out of the box".
example from a the build after running(not supported):
npm i
and
npm run start
example from a live sample:
example from the esm-cdn folder(and what i expected to get):
AndyGup
@litchokay we were able to reproduce this, it's because the webpack sample doesn't set the HTML viewport.
In the webpack sample under /public/index.html try add this:
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
AndyGup
Hi @litch I'm unable to determine what's going on from the screen shots. Are all three screenshots taken using the iPhone 12 Pro simulator mode? That phone has a native resolution of 2532 x 1170 at 460ppi which can make UI elements look really small when running in simulation mode in a desktop browser.
litch
hi @AndyGup ,
the screenshot is just an example, the problem persists in every mode,
when working from the webpack build mobile support is non-existent.
heres a side to side of webpack and the esm-cdn folder:
both should hold the same code and look the same unsimulated,
i  tested examples on a production server too, the problem is happening on the phone (non simulated).
AndyGup
litch
it works! thanks @AndyGup
