Measurement Widget Customization
960
01-31-2023 09:51 PM
Acharya
Hello Everyone,
I am trying to customize the dropdown menu from the measurement widget. I want to keep only the metric units and remove other units from the drop down menu.
Is it possible in 4.25 version?
Thank you so much in advance.
JoelBennett
MVP Regular Contributor
This appears to work:
const measurement = new Measurement({
	areaUnit: "hectares",
	linearUnit: "kilometers"
measurement.viewModel.watch("activeViewModel", function(newValue, oldValue, propertyName, target) {
	if (newValue) {
		switch (newValue.declaredClass) {
			case "esri.widgets.AreaMeasurement3D.AreaMeasurement3DViewModel":
			case "esri.widgets.AreaMeasurement2D.AreaMeasurement2DViewModel":
				newValue.unitOptions = ["square-millimeters","square-centimeters","square-decimeters","square-meters","square-kilometers","ares","hectares"];
				break;
			case "esri.widgets.DirectLineMeasurement3D.DirectLineMeasurement3DViewModel":
			case "esri.widgets.DistanceMeasurement2D.DistanceMeasurement2DViewModel":
				newValue.unitOptions = ["millimeters","centimeters","decimeters","meters","kilometers"];
				break;
