marker hide behind layer added on basemap
2860
03-11-2021 03:33 AM
rsharma
hi i am trying to show markers above webmap combined with a layer of nz boundaries, my markers hide behind this layer, when i use this webmap.
i have used gray basemap with a layer added on it in arcgis online webmap.
then i called this webmap.
i don't know how to show these markers above this webmap.
This is my code below
 require(["esri/core/watchUtils","esri/views/MapView", "esri/WebMap","esri/Graphic","dojo/dom-construct","esri/widgets/Popup","esri/geometry/Point","esri/layers/FeatureLayer", "esri/identity/IdentityManager", "esri/layers/GraphicsLayer",  "esri/geometry/support/webMercatorUtils"],
                function(watchUtils,MapView, WebMap,Graphic,domConstruct,Popup,Point,FeatureLayer, IdentityManager,  GraphicsLayer, webMercatorUtils) {
                    webmap = WebMap.fromJSON(<?=$basemap_string1 ?>);
                /////Start view part
                var view = new MapView({
                  map: webmap,
                  container: "booking_map",
                  center: [<?=$map_data_by_country1['long']?>,<?=$map_data_by_country1['lat']?>], // longitude, latitude
                  zoom:<?=$map_data_by_country1['zoom']-1?>
                ///Set min/max zoom
                view.constraints = {
                    minZoom: <?=$map_data_by_country1['zoom']?>,
                    maxZoom: <?=$map_data_by_country1['zoom']+3?>
                   /***Create Instance of graphics layer***/
                var graphicsLayer = new GraphicsLayer();
               /***Add graphics layer to WebMap***/
                webmap.addMany([ graphicsLayer]);
              *When view is ready
                view.when(function() {
                 var getmarkerb = <?php echo json_encode($bcoordinate); ?>;
                  addMarker(getmarkerb);
                });//End view.when
                Add marker on map MarkerGL coming from db
              var addMarker=function(getmarker){
              var index = 0;
              getmarker.forEach(function(marker){
             // settings.accommodation_name[index]=(settings.gettype[index]!="Accomodation")?"":settings.accommodation_name[index];
              var markerpt = new Point({
                          longitude: marker.x,
                          latitude: marker.y,
                          spatialReference: { wkid: 4326 }
              var changedSymbol=changedsymbol('Access Point');
              var markergra = new Graphic({
                          geometry:  webMercatorUtils.geographicToWebMercator(markerpt),
                          symbol: changedSymbol,
                          attributes: {
                                      newDevelopment: "new marker",
                                      state: "new"
                index++;
                graphicsLayer.add(markergra);
              });//End loop
            }//End addMarker
        Create symbol for marker
       var changedsymbol=function(markertype){
          var newurl=changedMarkerSymbol(markertype);
          const changedSymbol = {
            type: "picture-marker",
            url: newurl,
            width: "25px",
            height: "25px"
          return changedSymbol;
        send url of marker image to calling function
        var changedMarkerSymbol=function(markertype){
          switch(markertype){
            case "Access Point":
            return "<?=HHQL_PLUGIN_URL?>public/images/accesspointnew1.png";
        }//End changedMarkerSymbol
      });///end WebMap
rsharma
Hi
Can anyone help, i m looking for the solution but couldn't find any
nita14
thy to add your graphics layer and ser its index to 0.
https://developers.arcgis.com/javascript/latest/api-reference/esri-WebMap.html#addMany
webmap.addMany([ graphicsLayer], 0);
Does it help?
BR,
Adam
rsharma
No sorry @nita14 it doesn't work, the markers load first and then the layer load on it, and hide. the markers
nita14
Just try to do not use webmap. Construct the layers manually by url and add them to the map.
Just like in this example:
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=layers-feature...
BR,
Adam
