Mapview and hitTest with MapImageLayer ?
1440
09-09-2024 08:51 AM
LionelGOUBET
I have a mapView with a MapImageLayer and I try on a click on mapview the hitTest function
mapView.hitTest(event).then(function(response) {
if (response.results.length > 0) {
    response.results.forEach(function(result) {
if (result.graphic) {
console.log("Feature sous le clic:", result.graphic.attributes);
} else {
console.log("Aucun enregistrement trouvé sous le clic.");
No results ... it doesn't work
If I change the  MapImageLayer with a FeatureLayer (of my service MapImageLayer) on my mapview => it works
If I use a web map with my url from my MapImageLayer => it works
Is is normal ? the MapImageLayer is not  planned ?
What is the solution ? use QueryTask when I use a MapImageLayer ?
sample ! https://codepen.io/lgoubet/pen/YzoBaMJ and change bHitTest variable
Thanks for your help
LionelGOUBET
LionelGOUBET
the solution is perhaps to add each feature layer of the mapimage layer to the view map ...
LionelGOUBET
