map.infoWindow does not display [X] icon
1257
10-09-2012 11:11 AM
RichardDaniels
MVP Regular Contributor
I have a javascript web application at http://www.wsdot.wa.gov/Monument/gis/index.htm?Title=WSDOT%20Monument%20Mapping%20Engine%20v4.0 that works fairly well; however, the button you would expect to see on the right corner of the infoWindow does not display.
Any ideas on why it is not showing up?
Rich
__Rich_
In your CSS in the file at http://www.wsdot.wa.gov/media/styles/styles.css you have the following rule:
.hide {display:none;}
The anchor element which contains the x icon has class="hide".
(also, just so you know, there are a number of errors that occur in the page e.g. some of your widgets haven't been parsed/instantiated when you try to use them like the zoomprev button)
__Rich_
RichardDaniels
the pitfalls of reusing .css styles 😉 to keep a one-DOT look.
