Can't Use WMSLayer - TypeError: this.extent is undefined
1507
10-08-2012 08:41 AM
AlejandroVargas
I am using ArcGIS API for Javascript 3.2 and performing a simple test on using WMSLayer.  However, I am unable to use the WMSLayer.  Instead, I get these errors in Firebug:
[ATTACH=CONFIG]18258[/ATTACH]
I have modified the Esri sample located at http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/layers_wms.htm... in order to suit my environment-specific information such as my ArcGIS Server IP address and map services hosted on my ArcGIS Server.
This modified Esri sample is attached to this post; it is named WMSTest.txt.  Due to attachment restrictions, I had to change the .html extension to .txt.  Alos, in order to protect proprietary information, I have replaced our ArcGIS Server IP address and map service names with the following respective placeholders: [My_ArcGIS_Server_IP] and [My_Map_Service_Name].
Any suggestions or answers would be greatly appreciated.  Thanks!
JeffPace
the script you posted is using the 2.1 api
derekswingley1
If you're using ArcGIS Server services, why not use ArcGISDynamicMapServiceLayer?
AlejandroVargas
@jeff.pace: You're correct.  I meant to post another file.  Sorry about that.  I won't update the attachment as I am simply going to create another thread that more accurately describes my issue.
@swingley: I need to answer your question by rewinding and explaining what I'm attempting.  This thread is not exactly relevant to the real problem I am experiencing.  I will reply with a link to the new thread shortly.  Thanks!
