Map Height and Width is fixed to 400px when ESRI API is used with EXT Js
4160
09-29-2015 12:59 AM
ManiDeep
Hi Team,
I have integrated esri with extjs-4.2. I am getting the map element in the proper size for the first time when the screen loads.However i am not getting the map element in the proper size when trying to reload the map element alone. The map element is getting reset to 400*400 automatically, which am not able to change. Please find below supportive screenshots with following code.
Here the piece of code intiating the Map in Extjs.
Ext.getCmp('dashboardcontainer').add(Ext.widget('mapPanel'));
Screen Shots
First time Loading properly as below:
Second time it is getting shrink:
Dom For the First time and Second Time where it is changing automatically:
First Time
Second Time
Note: Convert the attachement to text ,Replace your bing key
KellyHutchins
Esri Notable Contributor
There are several suggestions in this thread that may help.
Re: Map Height is fixed to 400px when JS API is used with Bootstrap
ManiDeep
Hi Kelly,
Thanks for your Suggestion after changing of esri.css and esri.js to the latest version the issue is resolved.
<link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
<script src="http://js.arcgis.com/3.14/"></script>
Manideep.
