Loading KML
1355
05-03-2012 08:34 PM
ChristopherPiggott
I am having trouble loading KML.  I'm surprised, because from the docs it looks like it should be really simple.  My init looks like this:
var map = new esri.Map('map')
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
map.addLayer(basemap);
var kmlUrl = 'https://myserver.something.com/maptest/status.kml';
var kml = new esri.layers.KMLLayer(kmlUrl);
map.addLayer(kml);
What I notice is that it doesn't ever hit my server to retrieve the kml file.
Do I need to somehow trigger a refresh so that it loads the kml?  Or is what I did above enough?
--Chris
derekswingley1
Is your KML file publicly accessible?
RaphaelSiebenmann
This is the second thread where I have read that the KML file needs to be publicly available.  I find it very frustrating that this is not explicitly mentioned in the documentation.  For example,
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/layers_kmlbuff...
and
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/layers_kml.html
Should probably be modified to mention this very important piece of information!
KellyHutchins
Esri Notable Contributor
Hi Raphael,
We do mention that the KML layer needs to be publicly accessible in the API reference (see the first paragraph):
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/kmllayer.htm
But I agree that we should probably add this info to the sample descriptions too. We'll work on getting this info added to the sample descriptions for a future release.
