Legend Values for Unclassed Symbology
4367
8
09-01-2023 12:03 PM
JohnMax
I have a polygon layer with unclassed colors symbology that is showing a range of values in the legend from -9223372036854776000 - 9223372036854776000.  How can I hide or change this in the legend?  I only really want to show the color ramp or the actual data range of -99 to 17,200.  Thanks.
Sage_Wall
Thanks @JohnMax .  It looks like you are using the renderer as it was defined when publishing the service. Likely the easiest and most permanent way would be to modify the symbology for the layer in the original ArcGIS Pro project and republish the service. If that's not possible you can set your own renderer for the layer in the app code.  In this codepen I set two stops one at -99 and the other at 17,200 and set the label to "Parcel" for a simple renderer with a color visual variable.
https://codepen.io/sagewall/pen/jOXVyNN
Another sample showing basically the same thing:
https://developers.arcgis.com/javascript/latest/sample-code/visualization-vv-color/
Hope this helps 😀
SarahRijneke
Have you built pyramids and calculated statistics? I believe that should properly display your values.
JohnMax
This is actually a polygon layer which is symbolized as unclassed colors.
Sage_Wall
Hi @JohnMax. Could you please share a Codepen, StackBlitz or GitHub repo demonstrating how you created the renderer on the layer.
JohnMax
Here is some sample code:
<html lang="en">
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>
ArcGIS Maps SDK for JavaScript 4.27
</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.27/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.27/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require(["esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer","esri/widgets/Legend"], (
Map,
MapView,
FeatureLayer,
Legend
const map = new Map({
basemap: "hybrid"
const view = new MapView({
container: "viewDiv",
map: map,
center: [-113.58332, 37.10819], // lon, lat
zoom: 16,
* Add feature layer
const featureLayer = new FeatureLayer({
url: "https://agisprodvm.washco.utah.gov/arcgis/rest/services/Assessor/MapServer/14"
map.add(featureLayer);
const legend = new Legend({
view: view,
layerInfos: [
layer: featureLayer
// Add widget to the bottom right corner of the view
view.ui.add(legend, "bottom-right");
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
Sage_Wall
Hope this helps 😀
JohnMax
Thank you!!  There was no way I could see to change the symbology of the service that would change the values in the legend.  This is exactly what I needed. 🙂
Joe1
I am having the same exact issue however I don't have an understanding of the coding side of GIS. Could I get a step-by-step instruction on how to fix the problem.
I am using unclassed colors to symbolize a set of polygons by a range of numerical values and for some reason in my webmap legend I am getting an output of those numbers (-9223372036854776000 - 9223372036854776000)
JohnMax
I'm no expert, but this sample code helped me a lot.
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=visualization-vv-color
In the sample you define the symbology in a constant called renderer.  Then you add the it to the feature layer using renderer: renderer.  In this way you can control the legend text using the label: properties in the code.
