Legend Title / Layer Names
7483
7
09-16-2012 03:19 PM
KeithGanzenmuller
I need to suppress the Legend Title and the Layer Names.
Can't yet figure out how to show a legend without them.
Any help is appreciated.
Keith
KellyHutchins
Esri Notable Contributor
You can use css to prevent the layer names from displaying. The API reference for the Legend Widget lists the available css classes.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/legend.htm
Here's an example of css that I'd add if I wanted to  hide the display of the service title:
 .esriLegendServiceLabel {     display: none; }
DavideLimosani
try adding a title:" " in your legendInfos like this:
            var legend = new esri.dijit.Legend({
                map:map,
                layerInfos:[
   {layer:yourfirstlayer, title:" "},
   {layer:yoursecondlayer, title:" "}
            }, "legendDiv");
            legend.startup();
CraigMcDade
Hope this helps.
legendLayers.push({layer:layer,title:'YOUR TITLE'});
KellyHutchins
Muhammad_SherazAhsan
Thanks its helpful..
KeithGanzenmuller
Great, thanks everyone for your help.
KeithGanzenmuller
Hey Steve.
These questions and answers apply specifically to the Javascript API.
    display: none;
would go in the styles section and suppresses the output of the legend labels.
The other code would go in the script where you are creating your legend.
KeithGanzenmuller
Sorry about that, by the other code I meant the code snippets submitted by Davide and Craig in response to my question, included below.
                map:map,
                layerInfos:[
            }, "legendDiv");
            legend.startup();
These are two different ways to change the titles in the legend and would be included in the SCRIPT section of the code where you set up the legend.
