Legend example does not show map or legend
6910
22
06-04-2014 07:10 AM
PeterHoffman
I am using the Legend example and cannot get it to work. I am new to JavaScript.
The map services are publicly accessible and we are using ArcGIS server 10.2
Here is the code:
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Create Map and add a dynamic layer</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"/>
        <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
    <style>
      html, body, #mapDiv{
        padding: 0;
       height: 97%;
      width: 98%;
      margin: 1%;
      #rightPane {
      width: 20%;
      #legendPane {
      border: solid #97DCF2 1px;
    </style>
  <script src="http://js.arcgis.com/3.9/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/layers/FeatureLayer", "esri/dijit/Legend",
      "dojo/_base/array", "dojo/parser",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
      "dijit/layout/AccordionContainer", "dojo/domReady!",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/ImageParameters"
      ], function (
        Map, ArcGISDynamicMapServiceLayer, ImageParameters, FeatureLayer, Legend,
      arrayUtils, parser) {
        map = new Map("map", {
          sliderOrientation : "horizontal"
        var imageParameters = new ImageParameters();
        imageParameters.format = "PNG24"; //set the image type to PNG24, note default is PNG8.
        //Takes a URL to a non cached map service.
        var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("https://gisservices.suffolkcountyny.gov/arcgis/rest/services/Live_Layers_External/MapServer", {
          "opacity" : 0.9,
          "imageParameters" : imageParameters
        var rivers = new FeatureLayer("https://gisservices.suffolkcountyny.gov/arcgis/rest/services/Live_Layers_External/MapServer/1", {
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields:["*"]
      var waterbodies = new FeatureLayer("https://gisservices.suffolkcountyny.gov/arcgis/rest/services/Live_Layers_External/MapServer/2", {
        outFields:["*"]
      map.on("layers-add-result", function (evt) {
        var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
          return {layer:layer.layer, title:layer.layer.name};
        if (layerInfo.length > 0) {
          var legendDijit = new Legend({
            map: map,
            layerInfos: layerInfo
          }, "legendDiv");
          legendDijit.startup();
       map.addLayers(dynamicMapServiceLayer);
       map.addLayers([waterbodies, rivers]);
    </script>
  </head>
  <body class="claro">
<!--[if IE 7]>
<style>
  html, body {
    margin: 0;
</style>
<![endif]-->
<div id="content"
     data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="design:'headline', gutters:true"
     style="width: 100%; height: 100%; margin: 0;">
  <div id="rightPane"
       data-dojo-type="dijit/layout/ContentPane"
       data-dojo-props="region:'right'">
    <div data-dojo-type="dijit/layout/AccordionContainer">
      <div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
           data-dojo-props="title:'Legend', selected:true">
        <div id="legendDiv"></div>
      </div>
           data-dojo-props="title:'Pane 2'">
        This pane could contain tools or additional content
      </div>
    </div>
  </div>
  <div id="map"
       data-dojo-props="region:'center'"
       style="overflow:hidden;">
  </div>
</div>
</body>
</html>
TimWitt
In case you are looking for ideas, I have created this. It is pretty basic.
PeterHoffman
Yes, that is what we are looking for.
As a novice I am guessing the html is in one file, the javascript in a js folder and the css in a css folder?
TimWitt
Everything can go into the html document, just like in your example.
TimWitt
This is how it looks like.
PeterHoffman
I do not any code in your last post?
TimWitt
The attachment didn;t work for some reason, now it should be there.
TimWitt
One thing I forgot in my application.
before
parser.parse();
put
esriConfig.defaults.io.corsDetection = false;
This will eliminate problems in google chrome.
PeterHoffman
Yes, I got it, very nice, thanks.
I do not understand much of the code, not much from flash carries over.
TimWitt
Yes it takes a while getting used to. ESRI has some nice resources to learn from.
I taught myself everything. I started with html and javascript via codeacademy and then looked at the ESRI Javascript developers page. Once I kinda got the concept I started building the app, piece by piece.
Let me know if you have any question!
PeterHoffman
I will look into the code academy.
One advantage of the Javascript is the brevity of lines of code.
Flash template from ESRI was approx. 1000 files in a many folders. One typical mxml file would be several thousand lines.
Most of the time I just edit the config files which are xml.
