Legend example does not show map or legend
6897
22
06-04-2014 07:10 AM
PeterHoffman
I am using the Legend example and cannot get it to work. I am new to JavaScript.
The map services are publicly accessible and we are using ArcGIS server 10.2
Here is the code:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Create Map and add a dynamic layer</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"/>
        <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
    <style>
      html, body, #mapDiv{
        padding: 0;
       height: 97%;
      width: 98%;
      margin: 1%;
      #rightPane {
      width: 20%;
      #legendPane {
      border: solid #97DCF2 1px;
    </style>
  <script src="http://js.arcgis.com/3.9/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/layers/FeatureLayer", "esri/dijit/Legend",
      "dojo/_base/array", "dojo/parser",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
      "dijit/layout/AccordionContainer", "dojo/domReady!",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/ImageParameters"
      ], function (
        Map, ArcGISDynamicMapServiceLayer, ImageParameters, FeatureLayer, Legend,
      arrayUtils, parser) {
        map = new Map("map", {
          sliderOrientation : "horizontal"
        var imageParameters = new ImageParameters();
        imageParameters.format = "PNG24"; //set the image type to PNG24, note default is PNG8.
        //Takes a URL to a non cached map service.
        var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("https://gisservices.suffolkcountyny.gov/arcgis/rest/services/Live_Layers_External/MapServer", {
          "opacity" : 0.9,
          "imageParameters" : imageParameters
        var rivers = new FeatureLayer("https://gisservices.suffolkcountyny.gov/arcgis/rest/services/Live_Layers_External/MapServer/1", {
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields:["*"]
      var waterbodies = new FeatureLayer("https://gisservices.suffolkcountyny.gov/arcgis/rest/services/Live_Layers_External/MapServer/2", {
        outFields:["*"]
      map.on("layers-add-result", function (evt) {
        var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
          return {layer:layer.layer, title:layer.layer.name};
        if (layerInfo.length > 0) {
          var legendDijit = new Legend({
            map: map,
            layerInfos: layerInfo
          }, "legendDiv");
          legendDijit.startup();
       map.addLayers(dynamicMapServiceLayer);
       map.addLayers([waterbodies, rivers]);
    </script>
  </head>
  <body class="claro">
<!--[if IE 7]>
<style>
  html, body {
    margin: 0;
</style>
<![endif]-->
<div id="content"
     data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="design:'headline', gutters:true"
     style="width: 100%; height: 100%; margin: 0;">
  <div id="rightPane"
       data-dojo-type="dijit/layout/ContentPane"
       data-dojo-props="region:'right'">
    <div data-dojo-type="dijit/layout/AccordionContainer">
      <div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
           data-dojo-props="title:'Legend', selected:true">
        <div id="legendDiv"></div>
      </div>
           data-dojo-props="title:'Pane 2'">
        This pane could contain tools or additional content
      </div>
    </div>
  </div>
  <div id="map"
       data-dojo-props="region:'center'"
       style="overflow:hidden;">
  </div>
</div>
</body>
</html>
TimWitt
This is how it looks like.
TimWitt
Hey Peter,
The first issue I see is, that your requiere statements aren't lining up with your function statements. It needs to be changed to this:
require([
"esri/map",
"esri/layers/ImageParameters", "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
], function (
Map, FeatureLayer, Legend,
arrayUtils, parser, ArcGISDynamicMapServiceLayer, ImageParameters) {
Tim
JeffPace
you are running it on a webserver right? you can not just save an html file and run it locally.
PeterHoffman
Tim,
I made the changes as requested w/o luck.
Jeff,
I am using Aptana 3, every other example works as expected on my local PC.
TimWitt
Peter,
maybe this can get you started?
<!DOCTYPE html>
<html>
<head>
    on iOS devices-->
  <title>Map with legend</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
  <style>
    html, body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #rightPane {
      width: 20%;
    #legendPane {
  </style>
  <script>
    var map;
    require([
      "esri/map", "esri/layers/FeatureLayer", "esri/dijit/Legend",
      "dojo/_base/array", "dojo/parser", "esri/layers/ImageParameters", "esri/layers/ArcGISDynamicMapServiceLayer",
    ], function(
      arrayUtils, parser, ImageParameters, ArcGISDynamicMapServiceLayer
      parser.parse();
        basemap:"topo",
        center: [-73.0156, 40.8325],
        zoom: 12
          "opacity" : 0.9,
      var rivers = new FeatureLayer("https://gisservices.suffolkcountyny.gov/arcgis/rest/services/Live_Layers_External/MapServer/25", {
        outFields:["*"]
        outFields:["*"]
      //add the legend
            map: map,
          }, "legendDiv");
      map.addLayers([waterbodies, rivers, dynamicMapServiceLayer]);
  </script>
</head>
<!--[if IE 7]>
<style>
  html, body {
    margin: 0;
</style>
<![endif]-->
<div id="content"
  <div id="rightPane"
      </div>
      </div>
    </div>
  </div>
  <div id="map"
  </div>
</div>
</body>
</html>
I have centered the map on your county and added a different layer to illustrate that your legend is working.
Tim
PeterHoffman
Yes, that works great.
I guess I need a basemap to work with this example?
I had a dynamic example working w/o the basemap part.
TimWitt
Maybe once you have finished your map, you can play around with using your own basemap, but yes I think basemap is a requirement?
PeterHoffman
TimWitt
Peter,
try this:
<!DOCTYPE html>
<html>
<head>
    on iOS devices-->
  <style>
    html, body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #rightPane {
      width: 20%;
    #legendPane {
  </style>
  <script>
    var map;
    require([
    ], function(
      parser.parse();
        basemap: "topo",
        zoom: 12
        var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("https://gisservices.suffolkcountyny.gov/arcgis/rest/services/Basemap/MapServer");
        outFields:["*"]
        outFields:["*"]
      //add the legend
            map: map,
          }, "legendDiv");
      map.addLayer( dynamicMapServiceLayer);
  </script>
</head>
<!--[if IE 7]>
<style>
  html, body {
    margin: 0;
</style>
<![endif]-->
<div id="content"
  <div id="rightPane"
      </div>
      </div>
    </div>
  </div>
  <div id="map"
  </div>
</div>
</body>
</html>
Hope this helps!
Tim
PeterHoffman
Eventually I want to get the TOC widget working with my map services.
We are looking to migrate our flash based web apps to JavaScript.
Here is our GIS viewer in flash:
http://gis2.suffolkcountyny.gov/gisviewer/
I have also modified the Local Government Election Polling Places to use for Voter Information:
http://gis2.suffolkcountyny.gov/voterinformation/
