PrintTask - How to set the ExportWebMap JSON on PrintTask
991
06-05-2014 12:50 PM
DK5
I am trying to figure out how to print without a map UI.  I want to save ExportWebMap JSON out to a file for later use.  The requirement is to be able to select several saved maps to print from a list (so no map UI).  My plan was to save the ExportWebMap JSON when they save the map initially so I can just retrieve it and send it in the PrintTask.
I have seen posts related to this such as:
http://forums.arcgis.com/threads/65530-Best-method-for-forming-JSON-for-Export-Web-Map-(Printing)-ta...
and looks like I will have to generate my own ExportWebMap JSON and post it to the GIS server for export.  Any shortcuts on generating the ExportWebMap JSON?  Another post mentioned using printTask._getPrintDefinition() just for getting some of the JSON, but that throws me an error "Unable to get property layerIds of undefined or null reference".  Any other things I could try to get some of the ExportWebMap JSON or am I stuck with an all manual creation of it?
Let me know if there are any ideas out there or if anyone has implemented something similar.  Thanks!
