legend dijit ans secure mapservices : jsapi 2.3
3863
12
06-01-2011 06:21 AM
Marie-GilSeptfonds
My legendDijit works with my non securised mapservices.
But doesn't with my securised mapservices.
When I look the request with firebug the token argument isn't at the fine place in the url.
http://extranet.nimes.fr/website/extranet/AGS/geo_agglo21/php/proxy.php?http://extranet.nimes.fr/arcgis/rest/services/secure/PLU_ZONAGES/MapServer?token=xxxxxxxxxxxxxxxxxx/legend
Normally it should be
http://extranet.nimes.fr/website/extranet/AGS/geo_agglo21/php/proxy.php?http://extranet.nimes.fr/arcgis/rest/services/secure/PLU_ZONAGES/MapServer/legend?token=xxxxxxxxxxxxxxxxxx
Anybody has an idea ?
AndrewBrown1
Does anybody else have any suggestions regarding the legend widget?
On our development environment, the server is running SP2 without tokens and the legend appears flawlessly.
On our production environment, which is a separate server, it is running SP2 with tokens and the legend still isn't appearing. We're able to see it under REST, but "No Legend" keeps appearing where the legend is supposed to be.
Anybody have ideas?
We're also running JSAPI 2.4
BenSayers
Did you ever find out how to correct this problem?
Do I need to change the line in my proxy? I am using:
if(token != null) {
    reqUrl = reqUrl + (reqUrl.indexOf("?") > -1 ? "&" : "?") + "token=" + token;
My legend displays in Chrome, FF and Safari but I get the images missing in IE. I need to try and get this resolved as soon as possible any ideas?
Many thanks,
Ben
AndrewBrown1
There might be another thread regarding this issue, as I had trouble figuring out why the legend in IE wasn't working.
Anyhow, I cannot find my fix. I know it had to do something with this piece of code found in my TOC.js file:
if(!dojo.isIE && a.imageData && a.imageData.length > 0) {
    b = "data:image/png;base64," + a.imageData
  }else {
    if(b.indexOf("http") !== 0) {
      b = this.service.url + "/" + this.layer.id + "/images/" + b
It appears it handles IE browsers a little different, so the author had to modify the image connection slightly.
I also remember changing something to "https" and incorporating a method to use the token in the URL string.
Hope this helps,
Andrew
