legend dijit ans secure mapservices : jsapi 2.3
3821
12
06-01-2011 06:21 AM
Marie-GilSeptfonds
Hello,
My legendDijit works with my non securised mapservices.
But doesn't with my securised mapservices.
When I look the request with firebug the token argument isn't at the fine place in the url.
http://extranet.nimes.fr/website/extranet/AGS/geo_agglo21/php/proxy.php?http://extranet.nimes.fr/arcgis/rest/services/secure/PLU_ZONAGES/MapServer?token=xxxxxxxxxxxxxxxxxx/legend
Normally it should be
http://extranet.nimes.fr/website/extranet/AGS/geo_agglo21/php/proxy.php?http://extranet.nimes.fr/arcgis/rest/services/secure/PLU_ZONAGES/MapServer/legend?token=xxxxxxxxxxxxxxxxxx
Anybody has an idea ?
JeffPace
It looks like you are appending both the token value and the "/legend" value to the end of the url and they are happening in the wrong order.
do you have a line like this in your proxy?
if(token != null) {
    reqUrl = reqUrl + (reqUrl.indexOf("?") > -1 ? "&" : "?") + "token=" + token;
my guess is that you are appending the "/legend" after generating the proxy url, if you do it first you should be fine.
Marie-GilSeptfonds
in my proxy.php i've this part of code
if ($token) {
    $targetPath .= (stripos($targetPath, "?") !== false ? '&' : '?').'token='.$token;
JeffPace
Look at the $targetPath before and after that statement.  My guess is this is where the token is being inserted into the wrong location and you might need to modify that statement.
Marie-GilSeptfonds
Indeed, I think the problem is here.
Thanx
Marie-GilSeptfonds
I found a solution.
When the proxy.php test the token (if ($token) {...}) I add this part of code
if ($token) {
    if(stripos($parts[1], "/")){
      $targetUrl = str_replace('?token='.$token, "", $targetUrl, $count);
    $targetUrl .= (stripos($targetUrl, "?") !== false ? '&' : '?').'token='.$token;
Where $parts[1] is the result of $parts = preg_split("/\?/", $targetUrl);
In fact I test if the query contains a "/".
AndrewBrown1
If I'm logged in using the token, I don't even see the that the Legend is available under REST. I can see the layers and everything else, but not the legend.
What gives?
Marie-GilSeptfonds
Which AGS version do you have ?
AndrewBrown1
At the time of writing, we were using 10.00, as I thought the server already had SP2 installed.
But while we were in REST services, I noticed it was 10, so we upgraded to 10.02, SP2.
Sp2 is now installed but the legend still isn't appearing. We cleared the cache and stopped/started the service, but nothing worked. Any ideas?
Marie-GilSeptfonds
I'm in 10 sp1.
My REST console displays 10.01.
I've no other idea.
