KMLLayer Style support
4504
07-10-2013 03:22 PM
CorySmith2
I am displaying points from a KML file on my Javascript API map using esri.layers.KMLLayer().  The Placemarks in my KML file have a styleUrl defined as:
   <Style id="myStyle">       <LabelStyle>          <color>FFCCFFCC</color>       </LabelStyle>       <IconStyle>          <color>FF3F3FFF</color>          <Icon><href>http://mydomain.com/marker.png</href></Icon>       </IconStyle>    </Style>
The map is displaying my points using the marker.png as defined in this style, but I have two issues:
  1. Labels are not displayed.  I would like to display the Placemark's name as a label (ie always visible).
  2. The markers are the default color of the image (white).  I would like to marker to use the <color> in the <IconStyle>.
Is possible to do either of these?  Thanks!
CorySmith2
A follow up to my own question, if anyone else wants more control over their KML rendering...
I was not able to get the functionality I wanted using the KMLLayer.  Instead, I decided to load the KML file using jQuery's ajax function. Then for each placemark I built a PictureMarkerSymbol and TextSymbol and added them to the map.
A bit more javascript than I was hoping for, but in the end it gave me much greater control over my map symbols.
CorySmith2
EvanLevy
Could you post your code of how you did the jQuery method please?
I currently am trying to use KML links in my ArcGIS Javascript application but some symbology is not drawing correctly.  I also am curious about how the kml layer differs from a feature layer - are you able to perform analysis using the KML layers?  For example, if I had a line feature layer and I want to have a process that selects all line features that are within a distance of the KML Layer.  Also how do I go about adding my KML Layer into my legend?  I have not seemed to figure out how to do that.
