KML layer looks different in arcgis vs google map
1270
07-23-2013 04:51 PM
DamNguyen
I have a KML layer generated from a google map here: http://maps.google.com/maps/ms?ie=UTF8&hl=en&vps=2&jsv=344a&msa=0&output=nl&msid=2099036909162725171...
When used with google map API, it appears normal. When used with esri, there's a band of layer that goes across the map.
[ATTACH=CONFIG]26161[/ATTACH]
This is the code used to add the layer:
var kmlUrl = "http://maps.google.com/maps/ms?ie=UTF8&hl=en&vps=2&jsv=344a&msa=0&output=nl&msid=209903690916272517145.000490409fc924e00e3ee";
var kml = new esri.layers.KMLLayer(kmlUrl);
map.addLayer(kml);
I was wondering if you guys would have any ideas on what might have caused it. Thanks.
KenBuja
MVP Esteemed Contributor
If you look at that data in Google Earth, you also get the banding effect. There's a portion of the data that extends past 180° that looks like is what is causing the problem.
