keep dijit menuitem open after select
6636
15
07-26-2016 12:03 PM
BrianFoley1
I have a table of contents (TOC) with a legend that allows me to turn on/off layer in my map.  I placed my the TOC in a dijit menubar across the top of my page. When I make a selection from the TOC to turn on/off a layer, I want the TOC to stay opened, but it closes immediately after I select a layer.  Any ideas ?
RobertScheitlin__GISP
Brain,
  Sure here is a sample:
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title>TOC</title>
    <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.17/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.17/esri/css/esri.css" />
    <link rel="stylesheet" type="text/css" href="agsjs/dijit/css/TOC.css" />
    <style>
        html,
        body {
            height: 98%;
            width: 98%;
            margin: 0;
            padding: 5px;
            font-family: helvetica, arial, sans-serif;
            font-size: 90%;
        #header {
            position: fixed;
            top: 0;
            width: 100%;
            height: 50px;
            left: 0;
            background: silver;
        #content {
            position: fixed;
            top: 32px;
            width: 100%;
            height: 100%;
            left: 0;
            margin: 0;
            border: 0;
        #footer {
            position: fixed;
            bottom: 0;
            width: 100%;
            height: 35px;
            left: 0;
            background: silver;
        #map {
            position: fixed;
            width: 100%;
            height: 100%;
            border: 0;
            margin-left: -15px;
            margin-top: -15px;
            margin-right: -15px;
        #tocDiv {
          background-color: silver;
          padding: 8px;
          overflow: auto;
          max-width: 600px;
          max-height: 500px;
        .IdentifyIcon {
            background-image: url("images/Identify.png");
            background-repeat: no-repeat;
            width: 18px;
            height: 18px;
            text-align: center;
        .FindIcon {
            background-image: url("images/query.png");
            width: 18px;
            height: 18px;
            text-align: center;
        .claro .dijitButton .dijitButtonNode,
        .claro .dijitDropDownButton .dijitButtonNode,
        .claro .dijitComboButton .dijitButtonNode,
        .claro .dijitToggleButton .dijitButtonNode {
            border: 0;
            padding: 2px 4px 4px 4px;
            color: #000000;
            border-radius: 0;
            box-shadow: none;
            background: none;
        .claro .dijitMenu {
            border: 1px solid gray;
    </style>
    <script type="text/javascript">
        var djConfig = {
            paths: {
                agsjs: "/js/agsjs"
    </script>
    <script src="https://js.arcgis.com/3.17/"></script>
        var map, toc, basemap, dynaLayer1, dynaLayer2;
        require([
            "dojo/dom",
            "dojo/parser",
            "dojo/on",
            "dojo/_base/lang",
            "esri/map",
            "esri/geometry/Extent",
            "esri/layers/ArcGISTiledMapServiceLayer",
            "esri/layers/ArcGISDynamicMapServiceLayer",
            "agsjs/dijit/TOC",
            "dijit/form/DropDownButton",
            "dijit/DropDownMenu",
            "dijit/MenuItem",
            "dijit/layout/BorderContainer",
            "dijit/layout/ContentPane",
            "dojo/domReady!"
        ], function(dom, parser, on, lang,
            Map, Extent, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
            TOC, DropDownButton, DropDownMenu, MenuItem) {
            parser.parse();
            var initialExtent = new Extent({
                xmin: -8119646.38042271,
                ymin: 4986891.42830988,
                xmax: -8102329.13378822,
                ymax: 4999699.14992532,
                "spatialReference": {
                    "wkid": 102100
            map = new Map("map", {
                extent: initialExtent,
                smartNavigation: false,
                slider: false
            basemap = new ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
            map.addLayer(basemap);
            dynaLayer1 = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/MapServer", {
                opacity: 0.8
            dynaLayer2 = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/LocalGovernment/Recreation/MapServer", {
                opacity: 0.8
            var h = map.on('LayersAddResult', lang.hitch(this, function(results) {
                dynaLayer1.setVisibleLayers([0]);
                dynaLayer2.setVisibleLayers([0, 1]);
                try {
                    toc = new TOC({
                        map: map,
                        layerInfos: [{
                            layer: dynaLayer1,
                            title: "Contaminated Areas",
                            collapsed: true,
                            slider: false
                            layer: dynaLayer2,
                            title: "Other Constraints",
                            collapsed: true,
                            slider: false
                    }, 'tocDiv');
                    toc.startup();
                    toc.on('load', function() {});
                    toc.on('TOCNodeChecked', function(rootLayer, serviceLayer, checked) {});
                    h.remove();
                    var myButton = new DropDownButton({
                        label: "Map Feature List",
                        dropDown: toc
                    dom.byId("header").appendChild(myButton.domNode);
                    var menu = new DropDownMenu({ style: "display: none;"});
                    var menuItem1 = new MenuItem({
                        label: "Identify Feature",
                        iconClass:"IdentifyIcon",
                        onClick: function(){ alert('Identify'); }
                    var menuItem2 = new MenuItem({
                        label: "Find Building",
                        iconClass:"FindIcon",
                        onClick: function(){ alert('Find'); }
                    menu.addChild(menuItem1);
                    menu.addChild(menuItem2);
                    var myButton2 = new DropDownButton({
                        label: "Identify Tools",
                        dropDown: menu
                    dom.byId("header").appendChild(myButton2.domNode);
                } catch (e) {
                    alert(e);
            map.addLayers([dynaLayer1, dynaLayer2]);
    </script>
</head>
<body class="claro">
    <div id="content" data-dojo-type="dijit/layout/BorderContainer" design="headline" gutters="true">
        <div id="tocDiv" style="display: none;"></div>
        <div id="header"></div>
        <div id="map" data-dojo-type="dijit/layout/ContentPane" region="center"></div>
    </div>
    <div id="footer"></div>
</body>
</html>
Brain,
  There is a lot left to questioning and interpretation here. What TOC (the LayerList dijit, AGSTOC, etc)? It would be way better for you to show your code .
BrianFoley1
Good idea Robert, I was a bit vague.  Here is my code :
<!DOCTYPE html>
<html>
<head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>TOC</title>
    <script src="scripts/jquery.min.js"></script>
    <script src="scripts/dropit.js"></script>
    <link rel="stylesheet" href="css/dropit.css" type="text/css" />
    <link rel="stylesheet" type="text/css" href="agsjs/dijit/css/claro.css">
    <link rel="stylesheet" type="text/css" href="agsjs/dijit/css/esri.css" />
<style>
        html, body { height: 98%; width: 98%; margin: 0; padding: 5px; font-family: helvetica, arial, sans-serif; font-size: 90%; }
        #header { position: fixed; top: 0; width:100%; height:50px; left:0; background:silver; }
        #content { position:fixed; top:32px; width:100%; height:100%; left:0; margin:0; border:0;}
        #footer { position: fixed; bottom: 0; width: 100%; height:35px; left:0; background:silver; }
        #map { position:fixed; width:100%; height:100%; border:0; margin-left:-15px; margin-top:-15px; margin-right:-15px; }
    </style>
        $(document).ready(function () {
            $('.menu').dropit();
        var djConfig = {
            parseOnLoad: true,
            packages: [{
                "name": "agsjs",
                "location": location.pathname.replace(/\/[^/]+$/, '') + '/../src/agsjs'
    </script>
    <script src="agsjs/dijit/init.js" ></script>
    <script src="agsjs/dijit/TOC.js"></script>
        dojo.require("agsjs.dijit.TOC");
        dojo.require("dijit.Dialog");
        dojo.require("dijit.DropDownMenu");
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        dojo.require("dijit.MenuBar");
        dojo.require("dijit.MenuBarItem");
        dojo.require("dijit.MenuItem");
        dojo.require("dijit.PopupMenuBarItem");
        dojo.require("esri.layers.FeatureLayer");
        dojo.require("esri.map");
        dojo.require("esri.dijit.Popup");
        dojo.require("esri.dijit.PopupTemplate");
    </script>
    <link rel="stylesheet" href="css/claro.css">
<script>dojoConfig = { async: true, parseOnLoad: true }</script>
    <script src='http://dojotoolkit.org/reference-guide/_static/js/dojo/dojo.js'></script>
        var map, toc, basemap, dynaLayer1, dynaLayer2, dynaLayer3, dynaLayer4, dynaLayer5, dynaLayer6, popup, SimpleMarkerSymbol, popup;
        var toolbar, Popup, domClass, domConstruct, Dialog;
        function init() {
            var initialExtent = new esri.geometry.Extent({
                    "wkid": 102100
            map = new esri.Map("map", {
                , smartNavigation: false
                , slider: false
            basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
            dynaLayer1 = new esri.layers.ArcGISDynamicMapServiceLayer("https://xxxx/ArcGIS/rest/services/xxxx/Contaminated_Areas_or_Facilites/MapServer", { opacity: 0.8 });
            dynaLayer2 = new esri.layers.ArcGISDynamicMapServiceLayer("https://xxxx/ArcGIS/rest/services/xxxx/Other_Constraints/MapServer", { opacity: 0.8 });
            var h = dojo.connect(map, 'onLayersAddResult', function (results) {
                try {
                    toc = new agsjs.dijit.TOC({
                        map: map,
                        layerInfos:
                                { layer: dynaLayer1, title: "Contaminated Areas", collapsed: true, slider: false }
                            , { layer: dynaLayer2, title: "Other Constraints", collapsed: true, slider: false }
                    }, 'tocDiv');
                    toc.startup();
                    dojo.connect(toc, 'onLoad', function () { });
                    dojo.connect(toc, 'onTOCNodeChecked', function (rootLayer, serviceLayer, checked) {
                    dojo.disconnect(h);
                catch (e) {
                    alert(e);
        dojo.ready(init);
    </script>
</head>
     <div data-dojo-type="dijit/MenuBar" id="header" >
         <div data-dojo-type="dijit/PopupMenuBarItem" style="width:23%;background:silver;border:none;font-family:Calibri;font-size:16px;">
              <span><img src="/images/i_layers_ESRI.png" height="23" width="23" />Map Feature List</span>
             <div data-dojo-type="dijit/DropDownMenu" id="editMenu" style="width:100px;margin-top:-5px;width:100px;background:silver;border:none;">
                 <div data-dojo-type="dijit/MenuItem"  style="width:100px;" >
                     <div id="tocDiv" style="height:100%;width:100px;font-family:Calibri;font-size:10px;word-wrap:break-word;"></div>
                 </div>
             </div>
         </div>
     </div>
     <div id="content" data-dojo-type="dijit.layout.BorderContainer" design="headline" gutters="true">
         <div id="map" data-dojo-type="dijit.layout.ContentPane" region="center"></div>
     </div>
</body>
</html>
Brain,
  A dojo menu item is always going to close the parent menu when clicked on. You need to consider using a DropDownButton or a button that just open a dojo dialog dijit.
Here is your code re-written in AMD style (you need to quit using Legacy style coding) and using a dropdownbutton (I have change map service urls and the location of the toc files):
<!DOCTYPE html>
<html>
<head>
    <title>TOC</title>
    <style>
        html,
        body {
            height: 98%;
            width: 98%;
            margin: 0;
            padding: 5px;
            font-size: 90%;
        .header {
            position: fixed;
            top: 0;
            width: 100%;
            height: 50px;
            left: 0;
            background: silver;
        #content {
            position: fixed;
            top: 32px;
            width: 100%;
            height: 100%;
            left: 0;
            margin: 0;
            border: 0;
        #footer {
            position: fixed;
            bottom: 0;
            width: 100%;
            height: 35px;
            left: 0;
            background: silver;
        #map {
            position: fixed;
            width: 100%;
            height: 100%;
            border: 0;
            margin-left: -15px;
            margin-top: -15px;
        #tocDiv {
          background-color: white;
          padding: 8px;
          overflow: auto;
          max-width: 600px;
          max-height: 500px;
    </style>
        var djConfig = {
            paths: {
                agsjs: "/js/agsjs"
    </script>
        require([
            "dojo/dom",
            "dojo/parser",
            "dojo/on",
            "dojo/_base/lang",
            "esri/map",
            "agsjs/dijit/TOC",
            "dojo/domReady!"
            TOC) {
            parser.parse();
                    "wkid": 102100
                slider: false
                opacity: 0.8
                opacity: 0.8
                try {
                    toc = new TOC({
                        map: map,
                        layerInfos: [{
                            layer: dynaLayer1,
                            collapsed: true,
                            slider: false
                            layer: dynaLayer2,
                            collapsed: true,
                            slider: false
                    }, 'tocDiv');
                    toc.startup();
                    h.remove();
                    var myButton = new dijit.form.DropDownButton({
                        dropDown: toc
                    dom.byId("dropDownButtonContainer").appendChild(myButton.domNode);
                } catch (e) {
                    alert(e);
    </script>
</head>
        <div id="dropDownButtonContainer" class="header"></div>
    </div>
</body>
</html>
BrianFoley1
Robert,
            Thanks for the quick reply.  I used the code you modified but this is what I’m getting.
Brian
Brain,
  As I mentioned the path to the agsjs was changed to match my file location so you need to change the path to match yours. Look at your browsers web console and you will likely see a 400 error.
BrianFoley1
Just saw that, it works now. Thanks Robert.
Brian,
  Be sure to mark the reply that answered your question as the "correct answer" (right now you have marked your reply as the correct answer).
BrianFoley1
Just corrected it
BrianFoley1
Robert,
     I want to add a feature (see below) to the header bar, in addition to the TOC.  Should I add another dropdownbutton, or could I add a dropdownmenu ?  And if I can add a dropdownmenu, how can I do that.
