JS API 4.17 sketch widget rectangle, how to get height width
2072
10-20-2020 07:57 AM
johnbrosowsky
How can you get height and width in screen pixels of a rectangle drawn with the sketch widget?
RobertScheitlin__GISP
Get the geometry (extent) use the xmin, ymin, xmax, ymax to create a points then the views toScreen method to get the point screen coordinates and do the math.
UndralBatsukh
Hi there,
You can listen to create event on the sketch. When the create operation is completed, check the tool that created a shape, then divide the rectangle polygon extent's width and height by the view resolution. This will give you the rectangle polygon's extent width and heights in pixels.
sketch.on("create", function(event){
  // when draw rectangle create event is completed
  if (event.state === "complete" && event.tool === "rectangle"){
     console.log(event.graphic.geometry.extent.width / view.resolution, "pixels");
     console.log(event.graphic.geometry.extent.height / view.resolution, "pixels");
Here is a doc for the MapView.resolution
-Undral
