Jest unit test with GraphicsLayer
1140
02-27-2024 01:36 AM
AdamPigg
I have a custom Experience Builder widget which itself works fine, but im having trouble writing a unit test for it.  The widget creates a GraphicsLayer in the constructor and the import for it looks like
import { GraphicsLayer } from "esri/layers/GraphicsLayer";
When it comes to the unit test, it fails with the error
TypeError: GraphicsLayer_1.GraphicsLaye is not a constructor
If i change the import to
import GraphicsLayer from "esri/layers/GraphicsLayer";
the error changes to
TypeError: GraphicsLayer_1.default is not a constructor
What am I missing, i tried adding a mock like
jest.mock("esri/layers/GraphicsLayer");
But that didnt help.
Tags (1)
AdamPigg
So, i can get past that error with the following mock:
jest.mock("esri/layers/GraphicsLayer", () => {
    return {
        __esModule: true,
        default: jest.fn().mockImplementation(() => {
            return {
                init: mockedExp
But then i get stuck on a similar error
TypeError: projection_1.default.load is not a function
Which so far ive been unable to mock...is there an easier trick im missing?
