Change Sketch/sketchViewModel rectangle/circle single click size
781
02-27-2024 09:04 AM
MatthewDriscoll
Is there a way to change the default size of a rectangle sketch single click?   The size seems to be determined by the scale you are currently viewing the map at, the more you zoom in the smaller the single click rectangle is.   For now I will default to freehand mode but, if possible, it would be nice to be able to change the size and behavior of a single click.
