Is there a way to enable the IntelliSense in VS2012/2010 for the ESRI modules in AMD?
1920
03-11-2014 03:31 PM
weiliang
I am new to JavaScript and ESRI JavaScript API. I am trying to enable the IntelliSense for the ESRI modules by using AMD, but it seems doesn't work. I have put the "jsapi_vsdoc12_v38.js" file in the VS solution, and reference with " <script type="text/javascript" src="Scripts/jsapi_vsdoc12_v38.js"></script>". But it seems that it doesn't work in the AMD. Is there a way I can enable it? Without IntelliSense, it will be too hard to coding.
Wei
Ravichandran_M_Kaushika
Please see my reply on Sep 04th:  it works like a piece of cake after implementing the steps.
http://forums.arcgis.com/threads/91035-What-IDEs-are-people-using-for-JavaScript-development
After that I have un-installed aptana studio.
regards
ravic
KenBuja
MVP Esteemed Contributor
However, currently I don't think the code assist will work with AMD. This is noted in the code assist page.
Note: these plug-ins do not yet support code that loads JS API  modules using AMD due to the nature of how modules are aliased once  loaded.
DasaPaddock
An alternative option is to use the TypeScript definition file that's available at:
https://github.com/Esri/jsapi-resources/tree/master/typescript
