Is there a bug with the Search widget for 4.26?
1117
03-07-2023 02:58 PM
_____
I keep just getting:
No results
There were no results found for "search term".
When there should be results. I'm upgrading apps to 4.26, and the Search widget just isn't working. I even tried a very simple example, and it's still not working.
'esri/widgets/Search'
Search
// SEARCH WIDGET
const sources = [];
sources.push({
    featureLayer: new FeatureLayer({
        url: 'OurServer/MapServer/2',
    displayField: 'gs_name',
    outFields: ['*'],
    searchFields: ['gs_name'],
    placeholder: 'Search for customer information.',
    maxResults: 3
const searchWidget = new Search({
    view: view,
    sources: sources,
    includeDefaultSources: false,
view.ui.add(searchWidget, {
    position: 'top-left',
    index: 0,
Super simple, but it just doesn't work. I don't see any network requests either.
Any idea what could be wrong here?
_____
I found out what was wrong not too long after posting, but for some reason I couldn't find this post, so I thought it was deleted or something.
Anyway, the problem is that featureLayer has been changed to just layer now. Once I made that change, then it worked.
sources.push({
    layer: new FeatureLayer({
    outFields: ['*'],
    maxResults: 3
JoelBennett
MVP Regular Contributor
There doesn't seem to be anything wrong with what you have as far as I can tell.  However, changes made to the Search widget in 4.25 have caused some folks to notice *apparently* missing results, so If you're upgrading from a version prior to 4.25, you might check out this thread.
_____
sources.push({
    outFields: ['*'],
    maxResults: 3
