Is it possible to scale PictureMarkerSymbol in a 3D SceneView?
1066
01-25-2023 08:33 AM
Col36
I'd like to be able to insert a Picture into a 3D scene and fix it's size in meters.
Currently, PictureMarkerSymbol doesn't seem to scale according to the size on the scene. I've tried setting ScaleSymbols on the GraphicsOverlay and setting the ReferenceScale on the map.
Also, tried using PictureFillSymbol but this doesn't display. Not sure how to pass in a polygon Geometry into DistanceCompositeSceneSymbol
GreteSoosalu
Hi @Col36, with which SDK are you working with?
Guessing by the classes and properties you mention, that it is not the JavaScript Maps SDK. Therefore, fro better visibility, I suggest you to repost the question in a community that corresponds  to the SDK you use.
