Is it possible to remove the Play, Forward and Backward buttons from a TimeSlider
1379
01-19-2024 02:35 PM
Josh-R
Is it possible to remove the Play, Forward and Backward buttons from a TimeSlider? This was asked over 10 years ago, but the codebase has changed a lot since then. Thanks!
Tags (1)
JoelBennett
MVP Regular Contributor
Yes, this can be done with CSS:
div.esri-time-slider__animation,
div.esri-time-slider__previous,
div.esri-time-slider__next {
	display: none;
JoelBennett
	display: none;
Josh-R
This worked. Thanks!
