Internet Explorer 11 scrolling bug
6788
11-27-2013 05:07 AM
KenDoman
I noticed what appears to be a bug with Internet Explorer 11 and the current version (3.7) of the JavaScript API. When I'm zooming in with the scroll wheel, the map zooms in. When I'm zooming out with the scroll wheel, the map zooms in. I've tested it on the "Create a map" example, and I get the same strange behavior.
Until I can find where to report bugs, I thought I'd share my findings here.
KenDoman
If you're interested in a workaround until things are fixed, add the following in the head portion of your html document.
[HTML]<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"/>[/HTML]
This will force IE11 to render the application as IE10.
JohnGravois
as per the documentation here, ie11 has not been certified as a 'supported' browser yet.
ThomasBoring
That didn't work for me, but this did:
    <meta http-equiv="X-UA-Compatible" content="IE=10, chrome=1" />
KevinGooss
The link you point to lists "Internet Explorer 7+" under supported browsers.
11 is more (+) than 7 so it would stand to reason that IE11 is supported or the docs are incorrect.
JohnGravois
hi kevin,
back in 2013, when i wrote that post, the documentation on that page listed "IE7-IE10".  The page was updated when we introduced official support for IE11.
