injecting esri js 3.3 collides with existing internal require.js library
725
04-03-2013 11:45 AM
erikyuzwa
Hi all,
We're trying to load up the ESRI 3.3 javascript for some testing, but we've discovered that the dojo loader that is used, collides with the existing require.js setup we've been using in our internal application.
Is there a simple way to make these 2 coincide without needing to overhaul our entire library to use dojo?
on the esri side we're using:
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3compact"></script>
thanks!
TylerRothermund
I'm having the same problem.  Any solutions???
ReneRubalcava
What kind of error are you getting? A multiple define or a a "require has no method on" error?
According to this ticket, it should be doable with latest API 3.5 as it's based on Dojo 1.8.3, but I have not tried mixing the two
https://bugs.dojotoolkit.org/ticket/15616
NigelAlford
anyone make progress with this?
JonathanUihlein
How to use RequireJS with Dojo - http://requirejs.org/docs/dojo.html
This led me to: https://bugs.dojotoolkit.org/ticket/15616
Some solutions and suggestions are in the comments. Hope this helps!
