ESRI ,DOJO and Websphere Portal
1004
09-15-2013 05:48 AM
vinayb
HI ALl,
I have cross posted this same question at StackOverFlowhttp://stackoverflow.com/questions/18813084/esri-dojo-and-websphere-portal but felt , audience here are more suitable so posting here too.
Below is description:-
I am using ESRI javascript api for the map in my application which is developed on WPS , my application is heavily developed using dojo 1.7 but the problem is I am using ESRI javascript api 3.6 for map which used dojo 1.8.3 now i removed dojo 1.7 and ESRI which internally loaded dojo 1.8.3 things are breaking but I load dojo1.8.3 minus ESRI things are fine. What could be the issue , is this something to do with ESRI or IS it sometime to do with WPS
JonathanUihlein
The errors thrown are appropriate for when one tries to load two different versions of DOJO.
This may or may not be useful:
https://developers.arcgis.com/en/javascript/jssamples/mapconfig_customdojo.html
