Initialize Editor throw error:
5616
03-17-2015 02:18 AM
MohammedAbdulMateen
Uncaught TypeError: Cannot read property 'decimalFormat' of undefined     Editor.js:522
code below:
require([
        "dojo/parser",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "esri/map",
        "esri/toolbars/edit", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/FeatureLayer", "esri/Color",
        "esri/config",
        "esri/tasks/GeometryService",
        "esri/urlUtils",
        "esri/arcgis/utils",
        "dojo/dom",
        "dojo/_base/array",
        "dijit/Toolbar", "esri/dijit/Popup", "dojox/layout/FloatingPane", "dojox/layout/ExpandoPane", "esri/toolbars/navigation", "esri/dijit/Print", "esri/tasks/PrintTemplate", "dojo/request/xhr", "dijit/form/ComboBox", "dijit/form/Button", "esri/dijit/editing/Editor", "esri/dijit/editing/TemplatePicker", "dojo/i18n!esri/nls/jsapi", "dojo/keys",
        "dojo/domReady!"
], function (parser, BorderContainer, ContentPane, Map, Edit, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer, FeatureLayer,Color, config, GeometryService, urlUtils, arcgisUtils, dom, array, Toolbar, Popup, FloatingPane, ExpandoPane, Navigation, Print, PrintTemplate, xhr, ComboBox, Button, Editor,TemplatePicker,jsapiBundle, keys
    loading = dojo.byId("loadingImg");  //loading image. id
    edtest = Editor;
   esri.config.defaults.io.alwaysUseProxy = false;
    esri.config.defaults.io.corsEnabledServers.push(app.AppCors_Url);
    esri.config.defaults.io.proxyUrl = app.proxy_Url;
    //Geometry Service
    geometrysvc = new esri.tasks.GeometryService(app.geometryService_Url);
    esri.config.defaults.geometryService = geometrysvc;
    popup = new esri.dijit.Popup(null, dojo.create("div"));
    var sliderPos = "top-right";
    if ($("#HdnLanguage").val() == "en-US") {
        sliderPos = "top-left";
  map = new Map("map", {
        sliderStyle: "large",
        sliderOrientation: "vertical",
        sliderPosition: sliderPos
    app.map = map;
    dojo.connect(app.map, "onUpdateStart", showLoading);
    dojo.connect(app.map, "onUpdateEnd", hideLoading);
    //Map extents change event
    dojo.connect(app.map, "onExtentChange", function (extent) {
        bExtentChange = true;
        previousExtent = extent;
        //scale
        scale = app.map.getScale();
        var ScaleValue = document.getElementById("lstscale");
        document.getElementById("lstscale").value = app.map.__LOD.scale;
        //Register UserOpen Application
        //dojo.byId("mouseCordinates").innerHTML = "<b>Lat : </b>" + pt1.y.toFixed(8) + ", <b>Long : </b>" + pt1.x.toFixed(8) + " / <b>X : </b>" + mp.x.toFixed(3) + ", <b>Y : </b>" + mp.y.toFixed(3) + ", <b> Scale : </b>" + scale;
        if (pt1 != undefined) {
            // for utm coordinates
            var getvar = ToUTM(pt1.y, pt1.x);
            var utmy = parseFloat(getvar.split('|')[0]);
            var utmx = parseFloat(getvar.split('|')[1]);
            var lang1 = $("#HdnLanguage").val();
            if (lang1 == "ar-SA") {
                dojo.byId("mouseCordinates").innerHTML = "<b>X : </b>" + pt1.x.toFixed(3) + ", <b>Y : </b>" + pt1.y.toFixed(3) + "/ <b> مستوى : </b>" + scale;
            else {
                dojo.byId("mouseCordinates").innerHTML = "<b>X : </b>" + pt1.x.toFixed(3) + ", <b>Y : </b>" + pt1.y.toFixed(3) + " / <b> Scale : </b>" + scale;
    app.map.disableClickRecenter();
    dojo.connect(app.map, "onLoad", mapReady);
    //LandBase Service
    app.BaseMapLandBase_Service = new ArcGISTiledMapServiceLayer(app.BaseMapLandBase_Url);
    if (app.BaseMapLandBase_Service.loaded) {
        SetLabels(app.BaseMapLandBase_Service);
    else {
        dojo.connect(app.BaseMapLandBase_Service, "onLoad", SetLabels);
        dojo.connect(app.BaseMapLandBase_Service, "onError", showMapServiceError);
    app.map.addLayer(app.BaseMapLandBase_Service);
    //ElectricGrid Service
    app.ElectricGrid_Service = new ArcGISDynamicMapServiceLayer(app.ElectricGrid_Url);
    app.PKMapservice_Service = new ArcGISDynamicMapServiceLayer(app.PKMapservice_Url);
    app.map.addLayer(app.ElectricGrid_Service);
    app.map.addLayer(app.PKMapservice_Service);
    customerLocationLayer = new esri.layers.FeatureLayer(app.PKEditingService_Url + "/" + customerlocationlayerid, {
        mode: esri.layers.FeatureLayer.MODE_SELECTION,
        outFields: ["OBJECTID", "ORDERNO", "DESCRPTION", "CREATED", "DISTRICTNAME", "DISTRICTNO", "AREANO", "MASARNO", "USERCREATED", "X", "Y", "USERID", "LASTMODIFIED"]
    operationsPolygonLayer = new esri.layers.FeatureLayer(app.PKEditingService_Url + "/" + kashfealayerid, {
        outFields: ["OBJECTID", "REQUISITENO", "CUSTOMERVIP", "CUSTOMERNAME", "ORDERTYPE", "DISTRICT", "DEEDNO", "DEEDDATE", "BLDPERMNO", "BLDPERMDATE", "NEAREST_CUSTOMER", "NEAREST_STATION", "STATUS", "MOBILE"
, "USERCREATED", "CREATED", "USERID", "LASTMODIFIED", "PLANNO", "PLOTNO", "NATIONAL_ID"]
    navToolbar = new esri.toolbars.Navigation(app.map);
    dojo.connect(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
    var EditEvent = dojo.connect(app.map, "onLayersAddResult", initEditingFunc);
    //Adding MapServices to Map
   app.map.addLayers([operationsPolygonLayer, customerLocationLayer]);
function initEditingFunc(){
var editr=new Editor();
MohammedAbdulMateen
I solved it by
1.first loading  jquery library  then arcgis library then customised javascript files
2.Bring all the imports from contentpage to master page.
Hope this helpfull for others
KenBuja
MVP Esteemed Contributor
When you initialize the Editor, you have to include the parameters that define the functionality of the editor widget (in params) and the HTML element where the widget should be rendered (in srcNodeRef).
var editr = new Editor(params, srcNodeRef);
As you can see in the documentation, these two items are required.
MohammedAbdulMateen
Thanks for your reply, the error is thrown at first line,i mean in require() statement,
this error started after updating arcgis javascript api from 3.7  to 3.12
any help highly appriciated.
require([
        "dojo/parser",
        "esri/map",
        "esri/config",
        "esri/urlUtils",
        "dojo/dom",
        "dojo/_base/array",
        "dojo/domReady!"
MohammedAbdulMateen
I solved it by
