infowindow.select(index) highlighting features out of order
5822
13
08-19-2014 07:53 AM
JeffPace
using javascript api 3.10
I am using a popup in a sidepanel.  When I click "next" (using the sample integrated in my application) it calls
map.infoWindow.selectNext();
onResultSummaryItemClick(map.infoWindow.selectedIndex);
which then calls
function onResultSummaryItemClick(idx) { // alert(idx);
 map.infoWindow.select(idx); // alert("index:"+map.infoWindow.selectedIndex);
var extent = map.infoWindow.getSelectedFeature().geometry.getExtent();
 if (!extent) { // alert(map.infoWindow.getSelectedFeature()+":"+map.infoWindow.getSelectedFeature().geometry);
map.centerAndZoom(map.infoWindow.getSelectedFeature().geometry, 18);
else
map.setExtent(extent, true);
However the selected feature highlight symbol is ending up first in the list, instead of last, so it is drawing UNDER the feature, and therefore isnt appearing highlighted.  If i click the feature, the highlight moves to the bottom of the list, and draws correctly.
PATHS after hitting next
PATHS after clicking to select
any ideas? Kelly HutchinsDerek SwingleyJonathan Uihlein
JonathanUihlein
Looking into this Jeff, thanks for the info.
DavidColey
MVP Frequent Contributor
Thanks for putting this up Jeff.  Michael and I are trying to utilized the side panel popup to hold the results from a gp model that is returning fetures and graphics based on the linear distance from a selected feature, basically a select by attribute of an input layer then re-selecting user-input features base on a linear extent
JeffPace
var popup = Popup({
                                    popupWindow: false
                                }, domConstruct.create("div"));
                                this.popup = popup;
                                //stub out for popup
                                //setup event handlers for the next/previous buttons
                                connect.connect(dom.byId("previous"), "click", lang.hitch(this, selectPrevious));
                                connect.connect(dom.byId("next"), "click", lang.hitch(this, selectNext));
                                //when the selection changes update the side panel to display the popup info for the
                                //currently selected feature.
                                connect.connect(popup, "onSelectionChange", lang.hitch(this, function() {
                                    lang.hitch(this, displayPopupContent(popup.getSelectedFeature()));
                                //when the selection is cleared remove the popup content from the side panel.
                                connect.connect(popup, "onClearFeatures", lang.hitch(this, function() {
                                    dom.byId("featureCount").innerHTML = "Click to select feature(s)";
                                    registry.byId("resultData").set("content", "");
                                    domUtils.hide(dom.byId("pager"));
                                //When features are associated with the  map's info window update the sidebar with the new content.
                                connect.connect(popup, "onSetFeatures", lang.hitch(this, function() {
                                    var summPane = registry.byId('rightPane');
                                    if (!summPane._showing) {
                                        summPane.toggle();
                                    //when features set, clear results and set new
                                    domConstruct.empty('resultSummaryTab');
                                    array.forEach(popup.features, lang.hitch(this, function(graphic, idx) {
                                        domConstruct.create('button', {innerHTML: graphic.getTitle(), id: "resultItem" + idx, 'class': 'nav'}, dom.byId('resultSummaryTab'));
                                        domConstruct.place("<br/>", "resultSummaryTab");
                                        connect.connect(dom.byId("resultItem" + idx), "click", null, lang.hitch(this, onResultSummaryItemClick, idx));
                                    dom.byId("featureCount").innerHTML = popup.features.length + " feature(s) selected";
                                    //enable navigation if more than one feature is selected
                                    popup.features.length > 1 ? domUtils.show(dom.byId("pager")) : domUtils.hide(dom.byId("pager"));
                                    popup.features.length > 1 ? registry.byId('rightTC').selectChild(registry.byId('resultSummaryTab')) : registry.byId('rightTC').selectChild(registry.byId('resultDetailsTab'));
                                //results handlers
                                function selectPrevious() {
                                    popup.selectPrevious();
                                    onResultSummaryItemClick(popup.selectedIndex);
                                function selectNext() {
                                    //  alert('next');
                                    popup.selectNext();
                                //onclick handler
                                    popup.select(idx);
                                    var extent = popup.getSelectedFeature().geometry.getExtent();
                                    if (!extent) {
                                        map.centerAndZoom(popup.getSelectedFeature().geometry, 18).then(lang.hitch(this,function(){
                                            popup.select(popup.selectedIndex);
                                    } else {
                                        map.setExtent(extent, true).then(lang.hitch(this,function(){
                                    if (idx === 0) {
                                        domUtils.hide(dom.byId("previous"));
                                        domUtils.show(dom.byId("next"));
                                    } else if (idx === popup.count - 1) {
                                        domUtils.show(dom.byId("previous"));
                                        domUtils.hide(dom.byId("next"));
                                    } else {
                                //POPUP FUNCTIONS
                                function displayPopupContent(feature) {
                                    if (feature) {
                                        //clear links tab
                                        domConstruct.empty('resultLinksTab');
                                        //get content and set to results tab
                                      // console.dir(feature);
                                        var content = feature.getContent();
                                        if(!content){
                                            content  = feature;
                            //          console.log('content');
                          //              console.dir(content);
                                        registry.byId("resultData").set("content", content);
                                        query(".attrTable").forEach(function(node, index, arr) {
                                            if(node){
                                                if(node.firstChild){
                                                    array.forEach(node.firstChild.children, function(child) {
                                                        if (child.lastChild.innerHTML === "") {
                                                            domConstruct.empty(child);
                                        //get links and set to links tab
                                        var links = feature.attributes.links;
                                        for (var key in links) {
                                            if (links.hasOwnProperty(key)) {
                                                if (links[key]) {
                                                    var a = domConstruct.create('a', {href: links[key], target: "_blank"}, dom.byId('resultLinksTab'));
                                                    var img = domConstruct.create('img', {src: "images/" + key + ".png"}, a);
                                                    domClass.add(img, 'resultLink');
                                //add lods so we can get to level 20
                                this.map = new Map("map", {
                                    infoWindow: popup,
                                    basemap: "streets",
                                    autoResize: true,
                                    sliderStyle: style,
                                    logo: false,
                                    showAttribution: false,
                                    lods: lods,
                                    minZoom:10
                                map = this.map;
DavidColey
Wow Jeff, you didn't have to do this, but thank you.
