infowindow close on touchscreens register map click event
1314
07-11-2017 11:01 AM
TylerWaring
Greetings,
I have a web map application that I am trying to optimize for touchscreens. I have a reverse geocode that brings up an info window with address details. On touchscreens, when I click the close button on the info window, another map click event is simultaneously fired... which subsequently revers geocodes another address and info window. How can I close the info window without registering a map click event. it is conceivable that the user would want to reverse geocode multiple consecutive locations, just not when they are closing the info window button.
Tyler
RobertScheitlin__GISP
Tyler,
   You can use dojo on pausable to pause the map click event handler when the close button is fired, or just use event.stopPropagation().
Tyler,
