import view from @argis/core
2182
08-09-2021 01:39 AM
KenjooYeap
I'm having a hard time figuring how to import "view" from "@arcgis/core/views/View" to use the `view.whenLayerview()` function` while trying to refactor the code to use WebPack.
I am getting the following error:
uncaught TypeError: _arcgis_core_views_View__WEBPACK_IMPORTED_MODULE_0__.whenLayerView is not a function
I have also tried using "import * as view from @arcgis/core.views/View" but that didn't help.
Thanks for your replies !
KenjooYeap
Thanks for your replies!
I found the problem, my error was trying to import view from @arcgis/core module while the view needed for the whenLayerView is the reference to the MapView. importing the view from where mapview is defined instead works.
BenElan
Esri Alum
I suggest using this sample as a starting point for your app:
https://github.com/Esri/jsapi-resources/tree/master/esm-samples/webpack
If your issue is still reproducible in that sample we can take a closer look.
AndyGup
Tagging onto Ben's comment, add this code to that sample and it should just work:
  map.add(layer);
  view.whenLayerView(layer).then((layerView) => {
    console.log(layerView);
  .catch((error) => {
    console.error(error);
KenjooYeap
