ImageryLayer renderingRule deprecated in 4.27
2245
10-04-2023 08:12 AM
JaredPilbeam2
MVP Alum
I updated my app to v. 4.27 from 4.24 and now I'm getting this warning. I changed the property from ImageryLayer to rasterFunction, however that caused the imagery not to draw. Any help appreciated.
EDIT: The app I'm  working with uses webmaps. In the webmaps are map services. Here is the script:
 <script>
        require(["esri/Map",
            "esri/views/MapView",
            "esri/widgets/Search",
            "esri/widgets/Locate",
            "esri/widgets/LayerList",
            "esri/layers/ImageryLayer",
            "esri/widgets/Legend",
            "esri/widgets/Expand",
            "esri/widgets/Swipe",
            "esri/WebMap",
            "esri/layers/support/RasterFunction",
        ], (Map, MapView, Search, Locate, LayerList, ImageryLayer, Legend, Expand, Swipe, WebMap, RasterFunction) => {
            //webmap IDs
            const webmapids = [
                "e67a8eb6768641c19d4a7c5df394dbf4", //DTM
                "bfc5b0242adb42bfb0fc41e54497dfc8", //DSM
                "6ed3d2e495db4e859a73d2a32ce3d576", //HEDEM
                "d653b18bc941458491e06e657e10f393", //Intensity
                "a9ab25b1c7204764b2fabad6fc7a4635", //IR
                "e6bab92ebc524072a3305ec8f128e8f8", //Soil
                "2f9acebfb8db4e10bb6dddab8d3239c7", //ClosedDepressions
            const webmaps = webmapids.map((webmapid) => {
                return new WebMap({
                    portalItem: {
                        // autocasts as new PortalItem()
            console.log("map constructor created")
            // add image services used in the swipe map
            const imagery2021 = new ImageryLayer({
                url: "https://gis.willcountyillinois.com/image/rest/services/Orthoimagery/Orthos_2021_6IN/ImageServer",
                rasterFunction: [],
                // title: "2021 Orthoimagery 6in",
            // webmaps[0].add(imagery2021);
             * Initialize the View with the first WebMap
            const view = new MapView({
                map: webmaps[0],
                container: "viewDiv"
            //use promise function.when to add the imagery layer after the webmap group layer, hence, rendering it over the group layers
            view.when(function () {
            // create a new Swipe widget
            const swipe = new Swipe({
                leadingLayers: [imagery2021],
                // trailingLayers: [imagery2021],
                position: 35, // set position of widget to 35%
                dragLabel: "drag left or right",
                view: view
            // add the widget to the view
            view.ui.add(swipe);
            * On a button click, change the map of the View
            document.querySelector(".btns").addEventListener("click", (event) => {
                const id = event.target.getAttribute("data-id");
                if (id) {
                    const webmap = webmaps[id];
                    view.map = webmap;
                    webmap.when(function () { webmap.add(imagery2021); });
                    const nodes = document.querySelectorAll(".btn-switch");
                    for (let idx = 0; idx < nodes.length; idx++) {
                        const node = nodes[idx];
                        const mapIndex = node.getAttribute("data-id");
                        if (mapIndex === id) {
                            node.classList.add("active-map");
                        } else {
                            node.classList.remove("active-map");
            // group widgets on right so expand does not cover other widgets on that side
            let expand1 = new Expand({
                expandTooltip: "info",
                view: view,
                content: document.getElementById("infoDiv"),
                expandIconClass: "esri-icon-question",
                group: "top-right"
            let expand2 = new Expand({
                expandTooltip: "legend",
                view: view,
                content: new Legend({
                    view: view,
                    style: "classic", // other styles include 'classic'
                expanded: false,
                group: "top-right"
            let expand3 = new Expand({
                expandTooltip: "layer list",
                view: view,
                content: new LayerList({
                    view: view,
                group: "top-right",
            view.ui.add([expand1, expand2, expand3], "top-right");
            //add search widget
            const searchWidget = new Search({
                view: view,
            const searchWidgetExpand = new Expand({
                content: searchWidget,
                expanded: false,
            //add search widget to the view
            view.ui.add(searchWidgetExpand, {
                position: "top-left"
            //locate widget
            const locateBtn = new Locate({
                view: view
            //add locate widget to the view
            view.ui.add(locateBtn, {
    </script>
JaredPilbeam2
MVP Alum
After creating a case, we found out it was not in the javascript. Rather, one (or all) of the layers in the webmap was causing the warning as it was rendering. I had a hand full of ArcGIS server web services (orthos and lidar) in the webmap. After creating a new webmap and adding those layers with the exact same properties, styles and effects the warning was no longer there. If anything, it's a work-around.
JaredPilbeam2
MVP Alum
JaredPilbeam2
MVP Alum
