Identify results show on left pane
1775
08-07-2014 05:43 AM
MayJeff
I have 3 map services to identify and try to use this example here :
https://community.esri.com/thread/106054?q=identify combine
How do you show the results on left pane instead of pop up info window.
<body class="claro">
        <div id="content" data-dojo-type="dijit/layout/BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
            <div id="header" data-dojo-type="dijit/layout/ContentPane" region="top">
            </div>
            <div data-dojo-type="dijit/layout/ContentPane" id="leftPane" region="left" splitter="true">
      <div id="tabs" dojoType="dijit/layout/ContentPane" style="width:385px; height:150px;">
      </div>
            </div>
            <div id="map" data-dojo-type="dijit/layout/ContentPane" region="center">
            </div>
        </div>
    </body>
Thank you.
ReneRubalcava
Esri Frequent Contributor
Here is a sample that shows how to display popup information inside a sidepanel.
TimWitt2
May,
you could use html.set to feed the information you retrieve into your content pane.
dojo/html — The Dojo Toolkit - Reference Guide
Hope this helps!
Tim
MayJeff
Tim,
Can you show me or give me an example how to I place it inside the code?  Thank you.
ReneRubalcava
