Identify point features that fall within a buffer
4723
14
09-18-2013 01:03 PM
GaneshSolai_Sambandam
HI GIS folks,
Can you help me to find out the problems in my code with respect selecting features that fall within a buffer distance. I am actually geocder widget to find location and used the geocoded point feature to buffer around that point to create a buffered polygon. Once done, I want query against my customer feature layer to identify my point feature layer that fall within my buffered polygon.
The code below works fine upto buffering a point features, but it cannot identify the points that fall within  a buffer.
Can any one Please........................help me.
var map;
var gPoint;
var gsvc;
var gGraphic;
var graphic;
var locator;
var currentLocation;
var watchLocation;
var myQueryTask;
var myQuery;
require(["dojo/ready", "dojo/on",
    "esri/map", "esri/config", "esri/dijit/Geocoder", "esri/geometry/screenUtils", "esri/geometry/Extent", "esri/geometry/Point", "esri/geometry/webMercatorUtils", "esri/tasks/locator", "esri/graphic", "esri/SpatialReference",
    "esri/layers/FeatureLayer", "esri/layers/KMLLayer", "esri/tasks/QueryTask", "esri/tasks/query", "esri/tasks/RelationParameters", "esri/tasks/GeometryService", "esri/tasks/BufferParameters",
    "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/PictureMarkerSymbol", "esri/symbols/Font", "esri/symbols/TextSymbol", "esri/InfoTemplate",
    "esri/dijit/BasemapGallery", "esri/arcgis/utils",
     "dojo/_base/array", "dojo/_base/Color",
    "dojo/number", "dojo/parser", "dojo/dom", "dojo/dom-construct", "dojo/query", "dijit/registry",
     "dijit/form/Button", "dijit/form/TextBox", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "dijit/layout/TabContainer", "dijit/Menu", "dijit/TitlePane",
      "dojo/domReady!"
], function (ready, on, Map, esriConfig, Geocoder, screenUtils, Extent, Point, webMercatorUtils, Locator, Graphic, SpatialReference,
    FeatureLayer, KMLLayer, QueryTask, Query, RelationshipParameters, GeometryService, BufferParameters, SimpleMarkerSymbol, SimpleLineSymbol, PictureMarkerSymbol, Font, TextSymbol, InfoTemplate, BasemapGallery, arcgisUtils, arrayUtils, Color, number, parser, dom, domConstruct, query, registry) {
    ready(function () {
        parser.parse();
        esri.config.defaults.io.proxyUrl = "http://localhost:53303/proxy/proxy.ashx"; // for ASP.net application use this proxy.
        // esri.config.defaults.io.proxyUrl = "/proxy";
        //  esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
        esri.config.defaults.io.alwaysUseProxy = false;
        // var startExtent = new Extent(2264982.7047277316, 6425602.130388378, 1726864.6604362514, 8240522.929991121,
        //  new SpatialReference({ wkid: 102100 }));
        // var initialExtent = new Extent({ "xmin": -2550392, "ymin": 6093330, "xmax": 1852380, "ymax": 9028512, "spatialReference": { "wkid": 102100 } });
        var initialExtent = new Extent({ "xmin": -2335145.742961492, "ymin": 6433321.958737379, "xmax": 1656701.6222024914, "ymax": 8248242.758340122, "spatialReference": { "wkid": 102100 } });
        map = new Map("map",
                extent: initialExtent,
                basemap: "osm",
                zoom: 3,
                sliderPosition: "top-right",
                sliderStyle: "small"
        // Geocoder Widget
        var geocoder = new Geocoder({
            arcgisGeocoder: { Placeholder: "Find a place" },
            autoComplete: true,
            map: map
        }, dom.byId("Search"));
        geocoder.startup();
      //  map.on("load", enableSpotlight);
        geocoder.on("select", showFindLocation);
        geocoder.on("clear", removeSpotlight);
        function showFindLocation(evt) {
            map.graphics.clear();
            gPoint = evt.result.feature.geometry;
            var gSymbol = new SimpleMarkerSymbol();
            gSymbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE).setColor(new Color([255, 0, 0, 0.5]));
            gGraphic = new Graphic(gPoint, gSymbol);
            map.graphics.add(gGraphic);
            map.infoWindow.setTitle("Search Result");
            map.infoWindow.setContent(evt.result.name);
            map.infoWindow.show(evt.result.feature.geometry);
            var spotlight = map.on("extent-change", function (extentChange) {
                var geom = screenUtils.toScreenGeometry(map.extent, map.width, map.height, extentChange.extent);
                var width = geom.xmax - geom.xmin;
                var height = geom.ymin - geom.ymax;
                var max = height;
                if (width > height) {
                    max = width;
                var margin = '-' + Math.floor(max / 2) + 'px 0 0 -' + Math.floor(max / 2) + 'px';
                query(".spotlight").addClass("spotlight-active").style({
                    width: max + "px",
                    height: max + "px",
                    margin: margin
                spotlight.remove();
        function enableSpotlight() {
            var html = "<div id='spotlight' class='spotlight'></div>"
            domConstruct.place(html, dom.byId("map_container"), "first");
        function removeSpotlight() {
            query(".spotlight").removeClass("spotlight-active");
            map.infoWindow.hide();
        // Buffer -Point features based geocoder widget location
        gsvc = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        on(dojo.byId("Buffer"), "click", buffer);
        function buffer() {
            var bufferParameters = new BufferParameters();
            bufferParameters.distances = [dojo.byId("distance").value];
            // bufferParameters.distances = [1];
            bufferParameters.bufferSpatialReference = new SpatialReference({ wkid: 102100 });
            bufferParameters.outSpatialReference = map.spatialReference;
            bufferParameters.unit = GeometryService[dojo.byId("unit").value];
            bufferParameters.geometries = [gPoint];
            gsvc.buffer(bufferParameters, bufferDraw);
        function bufferDraw(geometries) {
            var symbol = new esri.symbol.SimpleFillSymbol("none", new esri.symbol.SimpleLineSymbol("solid", new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));
            var graphic = new esri.Graphic(geometries[0], symbol);
            map.graphics.add(graphic);
            addSBILocations(graphic);
        function addSBILocations(Results) {
            // SBI Branch Locations - Feature Service created by Ganesh
            var infoSBITemplate = new InfoTemplate("SBI Bank Locations", "Bank Name: ${BankName}<br/>" + "Bank Address: ${BankAddres}<br/>" + "Manager Name: ${Manager}<br/>" + "Opening Time: ${Time}");
            var flSBIUrl = "http://services1.arcgis.com/rHig23wEINZ1MKYI/arcgis/rest/services/SBI_BankLocation/FeatureServer/0";
            var flSBI = new FeatureLayer(flSBIUrl, {
               mode: FeatureLayer.MODE_SELECTION,
                outFields: ["BankName", "BankAddres", "Manager", "Time"],
                infoTemplate: infoSBITemplate
            var rsymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE).setColor(new Color([255, 0, 0, 0.5]));
            flSBI.setSelectionSymbol(rsymbol);
            map.addLayer(flSBI);
            var mySBIQueryTask = new QueryTask(flSBIUrl);
            var mySBIQuery = new Query();
            mySBIQuery.returnGeometry = true;
            mySBIQuery.outFields = ["BankName"];
            mySBIQuery.outSpatialReference = { wkid: 102100 };
        mySBIQuery.geometry = Results.geometry;
      flSBI.selectFeatures(mySBIQuery, FeatureLayer.SELECTION_NEW);
Hi Zou,
I changed my code in different way, and finally I got the results I wanted, but the only problem is: below code only works in Google chrome and Firefox browser, but it doesn't work on IE. On IE, it only works upuntil buffering stage, and it doesn't select features within them. I am wondering what would be the reason when the same code work in chrome and firefox, why not in IE?
anyone any clue?
var map;
var gPoint;
var gsvc;
var gGraphic;
var graphic;
var locator;
var watchLocation;
var myQueryTask;
var myQuery;
var graphic1;
var infoSBITemplate;
      "dojo/domReady!"
    ready(function () {
        parser.parse();
      //  esri.config.defaults.io.proxyUrl = "http://localhost:53303/proxy/proxy.ashx"; // for ASP.net application use this proxy.
                basemap: "streets",
                zoom: 3,
        // Geocoder Widget
            autoComplete: true,
            map: map
        geocoder.startup();
                var max = height;
                    max = width;
                    width: max + "px",
                    height: max + "px",
                    margin: margin
                spotlight.remove();
        function buffer() {
             graphic1 = new esri.Graphic(geometries[0], symbol);
            map.graphics.add(graphic1);
            addSBILocations(graphic1);
        var rsymbol = new esri.symbol.PictureMarkerSymbol({
            "angle": 0,
            "xoffset": 0,
            "yoffset": 10,
            "type": "esriPMS",
            "url": "http://static.arcgis.com/images/Symbols/Shapes/YellowPin1LargeB.png",
            "contentType": "image/png",
            "width": 24,
            "height": 24
             //  mode: FeatureLayer.MODE_SELECTION,
                mode: FeatureLayer.MODE_SNAPSHOT,
           // map.addLayer(flSBI);
            mySBIQuery.outFields = ["BankName", "BankAddres", "Manager", "Time"];
         mySBIQuery.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
          mySBIQueryTask.execute(mySBIQuery, addPoints);
        function addPoints(fset) {
            alert("Finally Reached!!!");
            var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 1), new Color([0, 255, 0, 0.25]));
            var resultFeatures = fset.features;
            for (var i = 0, il = resultFeatures.length; i < il; i++) {
                var pt_graphic = resultFeatures;
                pt_graphic.setSymbol(rsymbol);
                 pt_graphic.setInfoTemplate(infoSBITemplate);
                map.graphics.add(pt_graphic);
            // var resultExtent = graphicsUtils.graphicsExtent(resultFeatures);
            var resultExtent = esri.graphicsExtent(resultFeatures);
            map.setExtent(resultExtent);
HI Zou,
Can you tell me how to get spatialreference of a featurelayer and point features on my app.
I tried various options on my map to get the spatialreference of a feature layer and pointfeature.
If you have got any syntax, can you send it across to me.
JasonZou
FeatureLayer.fullExtent.spatialReference, or
FeatureLayer.graphics -> graphic.geometry.spatialReference
by Anonymous User
Not applicable
Was the initial issue of not being able to perform an identify on the points within the buffer ever resolved? I'm having the same issue. Points are returned, properly symbolized, etc. But a click on the returned point/graphic does nothing. infoTemplate is set and even returns successfully in the debug. I'm stumped.
Thanks!
rGibson
Hi Gibson
My code is working fine, now. But, it works fine with Chrome and Firefox, but, it doesn't work on IE.
If you are interested, I can send the code.
But, I do have created loads of additional  functionality - viewing all the data on dgrid and selecting the selecting the rows on
them, which allows me to go to the selected point features / extent.
please, let me know, if you need any help.
regards
ganesh
