I have point data (Lat, long) and its associated image (Jpeg), and I want the web application that open the image by click the particular point using ArcGIS Javascript API. So please share your idea how can I do this. Thanks
3505
12-01-2015 10:04 PM
ChandanKori
I have point data (Lat, long) and its associated image (Jpeg), and I want the web application using ArcGIS Javascript API that open the image by click the particular point.
Thanks
TyroneBiggums
Look into this link. They are setting properties that have images as data. You could probably use this and customize it for displaying an image. There is probably an easier, Esri-like, way, but this is what I'd do. https://developers.arcgis.com/javascript/jssamples/widget_infowindowchart.html
RobertScheitlin__GISP
Chandan,
   The JS API provide a means of geo-referenceing an image file using the MapImage and MapImageLayer classes.
MapImage | API Reference | ArcGIS API for JavaScript
MapImageLayer | API Reference | ArcGIS API for JavaScript
SteveCole
Honored Contributor
If the photos are posted online, you can just add the photo's URL as an attribute item to your point layer and then hotlink it inside your infoWindow using a custom Content function. If the photos are being stored locally on your network, well........that gets more difficult. You could add them as attachments to your data or you're going to be dealing with HTML5 and the FIleReader API like this and this.
