I am trying to display a Tile layer using 4.8 API.
5331
10
08-14-2018 08:36 AM
by Anonymous User
Not applicable
Hi ,
 We were exploring 4.8 API. As a test. I created the following code which works with an ArcGIS online rest service(layer2) but does not work with Tile Layer (layer1).
I am uploading the code. The code contains layer1 and layer2. layer2 is for test which is an arcgis online layer. This layer is fine. When I try do display layer2 (which is our rest service) it does not display it.
on debugging in chrome I found the error which says (failed to load).
What I observe after click on the link below on error. I find the request goes like https.
I dont know understand why the request is going on https when my url starts with http.
The urls starting with https does not work in our environment. How do I make them send request like http.
                        https://mapgis.memphistn.gov/arcgis/rest/info?f=json
error.png //contains the error, debug on chrome.
Test Map.html // code which I am trying to display our layer.
by Anonymous User
Not applicable
Thank you so much. using machine name solved the problem on my local environment.
Murali
