I am having issues with the infowindow not showing up on click, despite the graphics having an infotemplate. Not sure if I am doing it incorrectly.
1948
09-17-2014 08:32 AM
DarinBierbaum
This is how I instantiate my graphic.
var pt = new esri.geometry.Point(jsonobj.longitude, jsonobj.latitude, this.map.spatialReference);
                    var sms = new esri.symbol.SimpleMarkerSymbol();
                    var infoTemplate = new esri.InfoTemplate("<b>THIS IS INFO</b>");
                    var graphic = new esri.Graphic(pt, sms, infoTemplate);
                    this.map.graphics.add(graphic);
TimWitt2
Darin,
maybe this example of a pop-up for a graphic can help you
Button Popup 1 - JSFiddle
Tim
TimWitt2
Darin,
Tim
DarinBierbaum
Hi Tim,
Thanks for the quick reply. Looking through your code I see how the buttons have the infowindow.show. I was under the impression that if you give a graphic an infotemplate when you create it that the default behavior is to show the infowindow when you click the graphic. Is this not the case. In the meantime I will keep fiddling with this code and see if I can get something similar to work in my program.
TimWitt2
In my example you can also click on the graphic and the infowindow will show, you don't have to click the button.
DarinBierbaum
Yes, this is where I am finding myself having trouble, because from my understanding the default behavior of a graphic with an infoTemplate is that on click it should display the infoWindow, but my graphics dont seem to do that . I will fiddle around with it some more and see if I can find out why.
Thanks again for your help!
