How to use the built in widgets like Directions in AMD Dojo (ArcGIS Api 4.27)
830
08-10-2025 04:13 AM
MirzaMuhammadAhsanAli
I am migrating the 3.x application into 4.27, there is directions widget imported as "esri/dijit/Directions", how can i import it in dojo AMD with api 4.27. there is widget.html and widget.js files. In 4.x there is only ESM import is available in the documentation, how can i import this in dojo - AMD like i had imported in 3.x.
@Sage_Wall , @TimWestern , Could you please help me here.
I found this ( esri/widget/Directions),  and its working, where I can find the documentation for this.
Thank You!
JoelBennett
MVP Regular Contributor
The 4.27 AMD implementation is esri/widgets/Directions; the 4.33 documentation is here, and although doesn't mention the AMD syntax, AMD is supported in 4.27 and should still be largely (if not completely) the same (that is, the properties and methods documented in 4.33 probably haven't changed much since 4.27).
JoelBennett
Noah-Sager
Hi @MirzaMuhammadAhsanAli, thanks for posting your question here.
Here is the 4.27 Directions widget sample for inspiration: https://codepen.io/noash/pen/vENWBvM?editors=1000
And here you can download the 4.27 version of the documentation (or other versions): https://developers.arcgis.com/javascript/latest/downloads/
