Adding a widget to the outside of a map div in react
1437
05-08-2024 01:38 AM
ClintonLunnUGS
Hi all,
I am trying put a search widget into a sidebar in my project app, but am running into some issues.
Issues I'm seeing:
  • when trying to render the SearchBar in my Toolbar component, the search widget seems to get correctly created but never appears in my sidebar.
  • if I put the SearchBar into the Header component (not a lazy loaded component), it works on page load, but if I save the SearchBar file again, the search bar disappears. See below for how I am implementing the SearchBar.
I've created a github repo to illustrate issues I am seeing. https://github.com/clintonlunn/arcgis-react-template. Any suggestions would be much appreciated.
import Search from "@arcgis/core/widgets/Search.js";
import React, { useContext, useEffect, useRef } from "react";
import { MapContext } from "../contexts/MapProvider";
function SearchBar() {
  const { view } = useContext(MapContext);
  const searchDivRef = useRef<HTMLDivElement | null>(null);
  useEffect(() => {
    let searchWidget: __esri.widgetsSearch;
    if (view && searchDivRef.current) {
      console.log("Creating search widget");
      console.log("View:", view);
      searchWidget = new Search({
        view: view,
        sources: [],
        container: searchDivRef.current,
      console.log("Search widget:", searchWidget);
    } else {
      console.log("View or searchDivRef.current is not available");
    return () => {
      if (searchWidget && searchWidget.destroy) {
        searchWidget.destroy();
  }, [view]);
  return <div ref={searchDivRef}></div>;
export default SearchBar;
Thank you,
Clinton
geo_sunriver
I'd love to see a response to this as well. Currently trying to do something similar.
I'm trying to build a custom directions component that is going to hit a pgRouting service, but I want to grab the data from the esri geocoder search source.
Search Widget -> get address from input -> push lat, lng to the start and stop -> refresh view in postgres to create route.
