How to use RangeValue domains in ArcGIS JavaScript API
3695
10
10-06-2014 05:07 PM
GeoffreyWest
I have a combo box that I would like to use a range value instead of the coded value.  What is the proper syntax?  Now I am attempting domain.ranges to no avail.
function PopulateQuantity(serviceRequestLayerFieldsQuantity) {
    var serviceRequestFieldsQuantity
    for (var i = 0; i < serviceRequestLayerFieldsQuantity.length; i++) {
        if (serviceRequestLayerFieldsQuantity.name == serviceRequestLayerInfo.QuantityFieldName) {
            serviceRequestFieldsQuantity = serviceRequestLayerFieldsQuantity.domain.ranges;
            break;
    var Quantity = { identifier: "id", items: [] };
    for (var i = 0; i < serviceRequestFieldsQuantity.length; i++) {
        serviceRequestFieldsQuantity.items = { id: serviceRequestFieldsQuantity.name, name: serviceRequestFieldsQuantity.name };
    var QuantityStore1 = new dojo.data.ItemFileReadStore({ data: QuantityFieldType });
    dijit.byId('cbQuantity').attr('store', QuantityStore1);
function PopulateQuantity(serviceRequestLayerFields) {
    for (var i = 0; i < serviceRequestLayerFields.length; i++) {
        if (serviceRequestLayerFields.name == serviceRequestLayerInfo.QuantityFieldName) {
            serviceRequestFields = serviceRequestLayerFields.domain.ranges;
            break;
    var QuantityType = { identifier: "id", items: [] };
    for (var i = 0; i < serviceRequestFields.length; i++) {
        QuantityType.items = { id: serviceRequestFields.name, name: serviceRequestFields.name };
    var QuantityStore = new dojo.data.ItemFileReadStore({ data: QuantityType });
    dijit.byId('cbQuantity').attr('store', QuantityStore);
Tags (1)
GeoffreyWest
I would like to maintain range value as the data that I am passing should be integers.  I have changed the domain to coded values 1-99 for the time being.
