How to use RangeValue domains in ArcGIS JavaScript API
3668
10
10-06-2014 05:07 PM
GeoffreyWest
I have a combo box that I would like to use a range value instead of the coded value.  What is the proper syntax?  Now I am attempting domain.ranges to no avail.
function PopulateQuantity(serviceRequestLayerFieldsQuantity) {
    var serviceRequestFieldsQuantity
    for (var i = 0; i < serviceRequestLayerFieldsQuantity.length; i++) {
        if (serviceRequestLayerFieldsQuantity.name == serviceRequestLayerInfo.QuantityFieldName) {
            serviceRequestFieldsQuantity = serviceRequestLayerFieldsQuantity.domain.ranges;
            break;
    var Quantity = { identifier: "id", items: [] };
    for (var i = 0; i < serviceRequestFieldsQuantity.length; i++) {
        serviceRequestFieldsQuantity.items = { id: serviceRequestFieldsQuantity.name, name: serviceRequestFieldsQuantity.name };
    var QuantityStore1 = new dojo.data.ItemFileReadStore({ data: QuantityFieldType });
    dijit.byId('cbQuantity').attr('store', QuantityStore1);
function PopulateQuantity(serviceRequestLayerFields) {
    for (var i = 0; i < serviceRequestLayerFields.length; i++) {
        if (serviceRequestLayerFields.name == serviceRequestLayerInfo.QuantityFieldName) {
            serviceRequestFields = serviceRequestLayerFields.domain.ranges;
            break;
    var QuantityType = { identifier: "id", items: [] };
    for (var i = 0; i < serviceRequestFields.length; i++) {
        QuantityType.items = { id: serviceRequestFields.name, name: serviceRequestFields.name };
    var QuantityStore = new dojo.data.ItemFileReadStore({ data: QuantityType });
    dijit.byId('cbQuantity').attr('store', QuantityStore);
Tags (1)
RiyasDeen
Hi Geoffrey,
Range value domain is a not an array of values like coded value domain, it is a range between minimum and maximum value.
rangedomain-amd | API Reference | ArcGIS API for JavaScript
GeoffreyWest
Hi Riyas,
Thank you for your note.  I understand that the range value is not an array like coded values, however, could you please point me to the syntax of range value?  I would like to reference a range of 1-99.
RiyasDeen
Did you try
serviceRequestLayerFields.domain.minValue;
serviceRequestLayerFields.domain.maxValue;
should work, if your field has range value domain.
GeoffreyWest
Hi Riyas,
Thank you for your note, this does not work.  I also do not receive any errors in my console either.
            serviceRequestFieldsQuantity = serviceRequestLayerFieldsQuantity.domain.minValue;
            break;
            serviceRequestFields = serviceRequestLayerFields.domain.maxValue;
            break;
RiyasDeen
Hi Geoffrey,
Have a look at this fiddle, Edit fiddle - JSFiddle is this what you are after?
GeoffreyWest
Hi Riyas,
This solution is not successful.  I have domains chosen as short integer from 0-99 on my database side.  See my edited code below.
            serviceRequestFieldsQuantity = serviceRequestLayerFieldsQuantity.domain.minValue + "-" +  serviceRequestFieldsQuantity.domain.maxValue;
            break;
            serviceRequestFields = serviceRequestLayerFieldsQuantity.domain.minValue + "-" +  serviceRequestFieldsQuantity.domain.maxValue;
            break;
RiyasDeen
Hi geoffery,
Can you provide bit more detail on what you use case is? I'm bit confused on what is that you are exactly after
GeoffreyWest
Hi Riyas,
Please see Public Information Center
I have an application using this template and I have added a number of other requests fields such as quantity.  See my screen shot.  I would like the quantity field to be a value domain.
RiyasDeen
Hi Geoffrey,
Have a look at this fiddle Edit fiddle - JSFiddle
You can use a function like convertRangeToCode and pass your fields with domain to this function, it'll convert the range domain into a coded value domain json object which you can use to populate your dropdown list.
If the domain in already a coded value domain, it'll be returned as is.
