How to update graphic location as you drag (extent type)
1194
09-06-2021 12:25 AM
yuray
 I'm wondering how to make the graphic follow the cursor as I drag it.
LinasSpraunius
In Javascript v3 I've done following:
this.map.on('mouse-drag-start', e=>{
this.map.disablePan()
this.startedMoving = true
this.map.on('mouse-drag', e=>{
if (!this.startedMoving) return
this.graphic.setGeometry(new Point(e.mapPoint.x, e.mapPoint.y, spatialReference))
this.map.on('mouse-drag-end', e=>{
this.map.enablePan()
yuray
Thanks for your reply.
I use (ArcJSAPI 4.4), which is Extent(new Extent(( xmin, xmax, ymin, ymax, spatialReference: xxx));) instead of Point.
