How to remove the highlight geometry after close the popup
1765
09-26-2022 05:34 AM
happygis
I have a popuptemplate defined on a featurelayer, I Click a feature,then display the popup with a highlighted feature, I close the popup by code "view.popup.close()",But,the highlight selected feature remaind in map,how to remove the highlighted feature?
BlakeTerhune
happygis
I didn't highlight any feature,so highlight must be null. the highlight is automatically by popup's behavior.
JeffreyWilkerson
Not sure why the highlight problem is occuring if your code didn't set it, but the highlight is attached to the layerview, maybe if after you close the popup you set the view.layerview.highlight.remove()?
ReneRubalcava
Esri Frequent Contributor
If you have a sample repro in codepen or github, would be helpful to track down the issue.
This sample works as expected when the popup closes via view.popup.close()
https://codepen.io/odoe/pen/LYmOwvY?editors=100
