How to remove layer from legend
3424
09-02-2016 09:00 AM
by Anonymous User
Not applicable
I think I am doing something wrong. When I use the Legend for the example in API javascript I get an extra layer that is not on my map named other. How do I remove this from my Legend.
RickeyFight
MVP Alum
What does the legend look like in the mxd for the service?
by Anonymous User
Not applicable
I render the layer in the web page. All the layer in that mxd are lines and points and one poly that is off.
RickeyFight
MVP Alum
If you look here: Legend | API Reference | ArcGIS API for JavaScript 3.17
It says in a few places that you can choose what layers display
<Object[]> layerInfosOptionalSpecify a subset of the layers in the map to display in the legend. If not set, all layers in the map will display in the legend. The order of the layers in the legend depends on the layerInfo array. See the layerInfos property description for a description of its object properties.
yanli
set the legend property  "defaultsymbol:false"
