Hi all,
I have a connector that displays a web map in a dashboard based on a selection. When the dashboard is opened, I am generating a token via backend and passing it to the front end to call IdentityManager.registerToken(), and then initializing the web map.
I am registering a token for both the web map endpoint and the layer endpoint:
IdentityManager.registerToken({
server: "https://{portalUrl}/portal/sharing/rest",
token: ArcGISToken.Token,
// userId: "admin_user", // optional but useful
expires: ArcGISToken.Expires
server: "https://{portalUrl}/mapping/rest/services",
});However, it still prompts a login on my dashboard that says "Please sign in to access the item on ...". Am I missing something here? I want to be able to silently authenticate and bypass the login as I've already used the username and password stored in the configuration to retrieve the token.
The issue was completely unrelated to how I've set up registerToken. When generating the token, I had to set client to requestip., and only the first registerToken was necessary.
