How to programmatically clear/reset drawn profiles in <arcgis-elevation-profile>
1114
04-13-2025 04:16 AM
EmrahAydemir
Hello ArcGIS Community,
I'm using @arcgis/map-components in a React project to create a 3D map. I need to clear/reset the elevation profiles drawn with <arcgis-elevation-profile> when a button is clicked, but I can't find a documented method to achieve this.
My current setup:
// Elevation Profile component
  ref={elevationProfileRef}
></arcgis-elevation-profile>
// Clear button
<calcite-button
  onClick={() => clearDrawings()}
  icon-start="trash"
></calcite-button>
I need something like this:
  function clearDrawings() {
    try {
      elevationProfileRef.current?.clear();
    } catch (error) {
      console.error("Error clearing drawings:", error);
Thanks in advance for your help!
Sage_Wall
Hi @EmrahAydemir ,
You should be able to do this by setting the input property to `null`
https://codepen.io/sagewall/pen/JooPGWX?editors=100
Sage_Wall
Hi @EmrahAydemir ,
EmrahAydemir
Its worked well, thanks you so much...
