How to place a label in the center of a polygon in Feature layer?
1081
07-11-2023 06:37 AM
PrashantR
I have a feature layer with polygons and I want to place a label in the center of the polygon. I tried with polylines and polygons both but with the current label placement options available I am not able to place it in the center.
Is there any way to do this?
-Smita-
Hi @PrashantR,
You can try:
1. to find the centroid of each polygon and set the label
2. if you are using LabelClass, then you can set the labelPlacement property
UndralBatsukh
Hi there,
The always-horizontal label placement for polygons always places the labels at the center of polygons. Is this what you are not seeing?  Here is a simple codepen that shows labels for polygon features: https://codepen.io/matt9222/pen/LYXeqdP?editors=1000
